dji goggles lose connection
199 1 8-21 14:24
djiuser_BSMS8CxE9Y7B
I connect white goggles to regular micro usb connector and i see goggles video for a few minutes then goes black and white and freezes, disconnects from drone.  Could it be I'm using a cheap micro usb cable?  I can't find my dji micro usb cable.
8-21 14:24
DJI Natalia
Hi there, thank you for reaching out. It's highly possible that using a third-party micro USB cable is causing the issue. Ensure that the micro USB cable you're using is compatible with both your goggles and the drone if can, kindly try a different micro USB cable and see if it helps.
Thank you for your understanding.
8-22 02:58
