Cant bind ronin thumb controller with Ronin-m
5544 4 2015-9-20
stewart
Flight distance : 6032398 ft
I know, I know, how hard can it be right? I have followed all the steps to the tee on the DJI Youtube tutorial. Cant get it to bind. One question, when you push the button to
bind, should there be a little tolerence? So like when you bind the inspire 1 to a new controller. When you push the little red button you can feel it give a little, like you know you are pushing a button? I'm finding that there is no movement when I am using an object to push through the tiny bind hole, it almost feels like the hole where you place the thin objuect to push the bind button is not lined up so no bind button is being pressed at all. What am I doing wrong?
2015-9-20
noipego
Greece
use a small paperclip to push the button...the led will blink for a few secs if button is pressed. While blinking, turn on the remote. if it doesn't work reboot and retry maybe. Also make sure the remote is enabled from the app.
2015-9-23
stewart
Yes, the paperclip did the trick Thanks.
2015-9-23
baymon1984
Has anyone successfully connected the ronin m to the thumb controller
2016-4-24
DJI-Adela
baymon1984@gmai Posted at 2016-4-25 00:40
If you have any problem with binding the thumb controller to your Ronin/Ronin-M, please review the Thumb Controller User Manual firstly at http://dl.djicdn.com/downloads/r ... _Manual_en_v1.0.pdf
2016-4-24
