Serg SSA
Flight distance : 10160502 ft
Russia
Montfrooij Posted at 9-26 22:56
If you render 30fps footage in 25fps, you will get frame skipping.
If your monitor is not running on something dividable by 30fps, you also get frame skipping.
This was a problem that I had with one of my monitors the other day, the refresh rate was not set right (for me)
Why render footage shot at 30fps at 25fps?
If it is really necessary, then during rendering it is necessary to specify that the material shot at 30 fps should be interpreted at 25 fps; there will be no dropped frames, but there will be a slight (17%) slowdown.
The problem of light flickering is related to the frequency of the power grid, in Europe it is 50 Hz, so when shooting at night it is better to set the shutter speed multiple of 50. For this reason SECAM also uses 25 frames per second and PAL uses 30 fps. But this is a consequence of the fight against power grid flickering, this does not mean that all analog systems with a frequency of 25 Hz are the basis of digital standards in Europe. You have confused cause and effect) |
