Horizon tilt Issue
2358 25 2015-9-21
Sir Edward K
I had a horizon tilt issue with my previous version of the P3 Pro firmware (1.3.20) and DJI Go App (iOS).   But after I upgraded to the new 1.4.10 version and calibrated the gimbal i have not been able to shake the horizon into a tilt.  Mine measured on a 27" monitor is 1/10th of an inch wider on left side of screen than on the right side of screen.  Before, I have had major tilt problems where I would have to take it up 200' site the horizon yaw and roll each way and then tilt the camera until the top edge would meat the horizon and it would have been off by a lot.  I would then have to pull up the gimble adjustment screen and adjust to the minus side (cannot remember now how much) but I think it was 6 clicks.
   If you upgraded to 1.4.10 and you still have the horizon problem but you have not re-calibrated, try this.  I have been monitoring mine and I cannot shake it enought to cause the problem now.
Single SelectVote, Total 61 people participate in voting
Your user group with no voting privileges
2015-9-21
AerialLens
What is meant by shake? Fast, forceful, movements, or just yawing the aircraft? Just trying to understand. Are you saying 1.4.0010 corrected the problem in your case? I had the tilt using an earlier firmware version, but corrected it using a technique not related to firmware at all - it was a mechanical misalignment, not one of the voting buttons here..."Other" maybe?
2015-9-21
Sir Edward K
AerialLens Posted at 2015-9-21 10:52
What is meant by shake? Fast, forceful, movements, or just yawing the aircraft? Just trying to under ...
Fast Roll and fast Yaw would always make my horizon tilt worse. On my previous version, I could not fix it with gimble calibration.  If I took it up high sighted the horizon and yawed or rolled at all I would get the drastic 6/10 of an inch tilt.  Now most of the time it is nearly 0 but every once in a while at the worst it is about 1/10  (measure on my 27" screen during playback) measure from one side to the other.  Darn, Yes I should have put other as a choice (too late now).
Thanks
2015-9-21
AerialLens
Sir Edward K Posted at 2015-9-21 12:19
Fast Roll and fast Yaw would always make my horizon tilt worse. On my previous version, I could not ...
Well, the good part is that yours is corrected now. That's great.
2015-9-21
Phuglie
Flight distance : 45226 ft
That's good news - not tested mine - been too busy - thanks for sharing.
2015-9-22
Sir Edward K
Phuglie Posted at 2015-9-22 07:17
Well from looking at the poll numbers it is only about 50% of us with new firmware that report better Horizon.  Hopefully yours will be better as well.
2015-9-22
toddf.perkins
also, which type of horizon tilt are we talking about. the permanent tilt, or the one that comes and goes?
2015-9-22
Sir Edward K
toddf.perkins@g Posted at 2015-9-22 15:58
also, which type of horizon tilt are we talking about. the permanent tilt, or the one that comes and ...
I guess  50% of us are talking about any kind of  horizon tilt issues as i don't care what kind they are as long as I don't have them anymore.  And I had it every time I flew before.  I was just hoping it was more than 50%.  So it was probably just the luck of the draw.
2015-9-22
Paniza
Flight distance : 1411801 ft
It still happens to me.
You can see it here, first scene:
I noticed that when I have the camera in an angle and I turn + tilt, when I let it go, the camera will still carry some of the tilt.
If the same happens in a windy day, there will be more tilt.
2015-9-22
Sir Edward K
Paniza Posted at 2015-9-22 16:24
Yes, that is pretty much how mine would act.  But I have not seen it lately since this upgrade.  I was hoping it was gone for good.
2015-9-22
islasila
Flight distance : 24170 ft
Philippines
Sir Edward K Posted at 2015-9-23 05:52
Yes, that is pretty much how mine would act.  But I have not seen it lately since this upgrade.  I ...
Same issue with horizon after 1.4 update.
2015-9-26
StevenQX
Flight distance : 287474 ft
islasila Posted at 2015-9-27 01:03
Same here, even with offeset, seems better for a while then seems that the offset that before was necessary, need to be reverted to zero because is tilted on the other side.
2015-9-26
dji.blitzk
Flight distance : 1752986 ft
when did 1.4.10 come out?  I dont see it on the download section...
2015-9-26
DJI-Dave
dji.blitzk Posted at 2015-9-26 19:54
I think they mean 1.4.0010 it has been out for about a month now.  some guys just call it 1.4.10 omitting the extra 00
here is a link for you
http://www.dji.com/product/phantom-3/download
Also could you please change you user name for me. You are not allowed to have DJI in your user name unless you work for DJI.
Thanks
Dave
2015-9-26
Sir Edward K
dji.blitzk Posted at 2015-9-26 21:54
Yes, sorry it is 1.4.0010  (I must have multiplied by 100 lol).
2015-9-27
bullingerbrian
I never had it until I upgraded.
2015-9-27
Sir Edward K
bullingerbrian@ Posted at 2015-9-27 09:15
I think from this experiment that the problem is like rolling dice.  Just because you don't have it does not mean that you won't the next time you fly or the next time you upgrade.  And from the responses it seems that more than half of us have the problem.
2015-9-27
dji.blitzk
Sir Edward K Posted at 2015-9-27 09:25
I just wanted to make sure we were all on the same page... hah
2015-9-27
Neville
Flight distance : 675499 ft
dji.blitzk Posted at 2015-9-28 00:41
I recalibrated the gimbal from a flat/level surface and have never had a problem.  Check your anti vibration shocks to ensure the four are seated correctly and not damaged.
2015-10-10
Kit Walker
I have the very first DJI GO release.., and know exactly what Sir OP is mentioning. It's very annoying.Everything can be perfectly level.., but sometimes a fast movement left or right.., then stop still..., I will notice the horizon is not level.
Sometimes I can do a full 360 turn.., and come back to see the horizon is now level without adjusting the gimbal.
2015-10-11
rodger
Flight distance : 20145135 ft
I have that problem after a few Cocktails
2015-10-12
jayhkr
rodger Posted at 2015-10-12 13:45
That's the way I should fly. Maybe it'll CORRECT my issue!
2015-10-12
rodger
jayhkr Posted at 2015-10-12 14:47
Corrects a lot of issues
2015-10-13
Paniza
The issue is still there along with the can't fly straight one.
It happens when you get strong winds side ways. It seems that the Phantom has a limitation side ways or double compensate.
2015-10-13
Sir Edward K
Paniza Posted at 2015-10-13 07:35
It happens when you get strong wind ...
The can't fly straight is really driving me crazy lately.   I take it up and forward and it goes up and forward / left and I stop and bring it back and do it again until if flies straight.  Why does it stop flying crooked after a bit?  Mine does anyway if I stop it when it happens and try again.  It is always when I take off and leave.
2015-10-13
Paniza
Sir Edward K Posted at 2015-10-14 00:30
The can't fly straight is really driving me crazy lately.   I take it up and forward and it goes u ...
It actually doesn't stop.
It is just that you didn't trigger the issue again.
2015-10-14
