DJI Gamora
Rounin Posted at 9-12 16:28
I managed to update the firmware and flyzones with Assistant 2.1.28 but for the life of me I can't find a way to activate. If anyone has some info on this it would be greatly appreciated.
I have tried the QuickTransferBand to Fixed 2.4GHz bandwith but no success.
Hi there,
Thank You for reaching out. For activation method you can refer to 47# comment. For QuickTransfer please follow the steps below;
It is able to connect DJI Neo to your smartphone via Wi-Fi and enter QuickTransfer mode, then download photos and videos to your smartphone at high speed.
In Mobile App Control, after the smartphone is connected to DJI Neo, enter QuickTransfer mode by going to the Album view.
When DJI Neo is not connected to the smartphone, you can tap the QuickTransfer or Wi-Fi Devices card on the home screen in DJI Fly to enter QuickTransfer mode. You can also go to Album in DJI Fly on your smartphone, and tap the lightning icon in the upper right corner to enter QuickTransfer mode.
When connecting the smartphone to DJI Neo for the first time, press and hold the power button of DJI Neo to confirm.
• The maximum download rate can only be achieved in countries and regions where the 5.8 GHz frequency is permitted by laws and regulations, when using devices that support 5.8 GHz frequency band and Wi-Fi connection, and in an environment without interference or obstruction. If 5.8 GHz is not allowed by local regulations (such as in Japan), or your smartphone does not support the 5.8 GHz frequency band, or the environment has severe interference, then QuickTransfer will use the 2.4 GHz frequency band and its maximum download rate will reduce to 6 MB/s.
• When using QuickTransfer, it is not necessary to enter the Wi-Fi password on the settings page of the smartphone in order to connect. Open DJI Fly and a prompt will appear to connect the device.
Use QuickTransfer in an unobstructed environment with no interference and stay away from sources of interference such as wireless routers, Bluetooth speakers, or headphones.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You! |
