2.4GHz Antenna Range Booster
3703 23 2015-9-21
snathla
Flight distance : 5045295 ft
I ordered this extender, has anyone used one and does it really work to extend the range as I don't get the range that is documented in the Inspire specs
2.4GHz Antenna Range Booster DJI Phantom 3 Inspire 1 Controller Signal Extender -
2015-9-21
ibdronin
I have been eye balling this extended range modification. Anyone here have this or have feedback positive or negative.
http://www.dronesetc.com/collect ... dvanced-antenna-kit
@ snathla - Let me know how the set that you purchased works out. Heck of alot cheaper!
2015-9-21
jones5r
Flight distance : 105722 ft
Yes it works. It turns your omni directional antennas into a directional. Which means when you use it the RC should be pointed in the direction of your A/C for maximum effectiveness. I was able fly down range 5200 meters and still had both control and video. The battery was the weak link. It's a cheap and effective way to boost your range and signal stability.
2015-9-21
SkySight
Flight distance : 143566828 ft
Yes, I'd also be interested in reading what you think. thanks
2015-9-21
bradleyrogers23
Where did you buy it from and how much was it?
2015-9-21
snathla
bradleyrogers23 Posted at 2015-9-21 20:54
I ordered it on eBay, have not gotten it yet but will report back on the signal. It was around $20.
2015-9-21
ibdronin
Okie dokie let us all know. I would be interested considering it's not expensive at all.
2015-9-21
Machoman
Flight distance : 1036959 ft
Austria
I didnt make a long range test but the signal is more stable to what I had before.
2015-9-22
mlpfw
bradleyrogers23 Posted at 2015-9-22 11:54
URL please.
2015-9-22
jones5r
This is the one i have:
http://www.ebay.ca/itm/Aluminum- ... rfer-/311445376063?
Higher quality made of all aluminum instead of plastic and tin foil. Unfortunately looks as though it has been discontinued by the seller. Other options are available.
2015-9-22
snathla
Here you go - http://www.ebay.com/itm/11175337 ... =STRK%3AMEBIDX%3AIT
2015-9-22
remltr
I find this interesting, but the thing that concerns me is the direction of the antenna booster. It appears to be pointing at the ground, even it just slightly, instead of the sky. Wouldn't you want to point your RC antennas downward then install the booster so that it is facing skyward?
2015-9-22
jones5r
remltr Posted at 2015-9-23 01:14
I find this interesting, but the thing that concerns me is the direction of the antenna booster. It  ...
The pic above shows the proper installation and application.
2015-9-22
dennis
I have been using one for a while now seems to work pretty good I have good strong signals.  I use small O rings on the antennas to keep it locked into place
2015-9-22
howie121218
well, very nice mod, but what's the point? I mean, i1 already can fly up to 3000 ft away, at least I did it without any signal losing. Why do we need more boost for the range, I think the range of i1 already good enough. Also the battery life only can do 18 -20 mins, so if you boost to far, you don't even have enough battery to get it back...just my thought.... I did range boost for phantom 2 + though...
Howie
2015-9-22
pi-inthesky
Flight distance : 13058 ft
Giuseppe.finizia@gmail.com two types tin foil and one slightly dearer copper foil finish well priced well made
2015-9-22
Machoman
Austria
As you might have red in my posting above I didnt do any range test - but I have much better signal in areas where before I got a connection warning. The Inspire can sure fly 9000ft without any mod but such a part helps for stability.
In 18 min the Inspire can fly at least 25.000ft not using top speed to get out longest flight time.
2015-9-22
remltr
jones5r Posted at 2015-9-22 13:12
Granted, but it just seems to me that pointing the reflectors towards the ground (even though slightly) and not towards the sky where your quad is is counter-intuitive.
2015-9-22
edlovrien.msn
I flew a mile out and back and screwed around for a few minutes and still have 50 percent left to play with no loss.  Impressive,     I don't know that I want to fly it much farther than that.
2015-9-22
mlpfw
jones5r Posted at 2015-9-22 23:54
Thanks for the url
2015-9-23
snathla
Just wanted to get back after getting the range booster went back to the water to see how far I could go. Normally I would get RC weak signal from 4800 ft to losing it at 5200. I was able to get to 6975ft today, not bad but expected a bit more.
2015-10-3
RichJ53
Flight distance : 1837356 ft
jones5r Posted at 2015-9-22 08:54
These are still available see new link below.... I ordered mine today
http://www.ebay.ca/itm/Aluminum- ... hash=item3d04ae7cbf
2015-10-3
jones5r
RichJ53 Posted at 2015-10-3 22:31
http://www.ebay.ca/itm/Alum ...
Good deal. I'm really happy with the purchase.
2015-10-3
snathla
Took a second flight with the Range Booster today and am really impressed with its range, did not push it beyond 13627 ft...Wow, think could have gotten farther but was chasing a barge and decided to take a few shots.
Booster New Range
Booster New Range
2015-10-4
