Retain settings, and Jerky footage
854 6 2024-9-15
TheStriff
Flight distance : 24839 ft
Hi All.
I have a Mini 4 Pro so will use the RC controller to configure the settings for the Neo (have a Neo on order)
But will the settings be retained on the drone?
Reason why I'm asking, is I intend to use the drone mostly for follow mode when trail running, and do not want to pack the controller, more bulk and added weight I don't want.
(Otherwise I would have used the Mini 4 Pro)
Does the Neo retain the settings, default settings the footage looks way too over sharpened and saturated,
Also a lot of videos I've seen, there's microsoft stutters / jerky footage, Especially noticable when panning on the drone, is this normal if so, not good at all.
BTW, please DJI bring all the options to the phone app....
2024-9-15
Bigplumbs
Flight distance : 620164 ft
I am very pleased with the fottage I am getting. I don’t think howeve the Neo will be fast enough to keep up with you running. It’s follow us very very good but I think running might be too fast
2024-9-15
fichek
Flight distance : 1378789 ft
Croatia
It will not retain sharpness or denoising settings, only what you can set inside DJI Fly when not using any RC. So pretty much just resolution/framerate and some QuickShots-specific settings like how far and high it will fly while following you or doing certain shots. That's it and it's definitely not enough since we know it *can* do better.
2024-9-15
TheStriff
fichek Posted at 9-15 22:21
Thanks.
Wow, that's very disappointing.
Hopefully DJIO will update it, so it can be configured and save more settings from the Phone app
2024-9-15
fichek
Croatia
TheStriff Posted at 9-15 22:56
Thanks.
Indeed. There are several topics with feedback already, and hopefully DJI reps will see this topic too and forward it to the relevant team.
2024-9-15
fichek
Croatia
I forgot to comment on the jerkiness. What you were probably seeing is 30fps footage in a 24fps youtube video. If you upload it at 30fps like a sane person, it's perfectly smooth.
2024-9-15
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We appreciate the additional information and your insights regarding this matter. Your comments and suggestions are important to us. Rest assured, your feedback has been noted and forwarded to the relevant team for their attention.
2024-9-16
