DJI Neo: The Limitations That Fans Defend
5045 18 9-16 02:04
jefersonalessan
Flight distance : 3144039 ft
Brazil
I made a post recently and was surprised by the loyalty of DJI fans. The Neo had all the potential to be a fun and safe drone, but it came with so many restrictions that limit its use. Many defenders say: 'Read the manual,' or that the drone is 'cheap.' But the issue isn't the price, it's the excessive limitations. You can’t fly it at night, over water (even though DJI shows it in official videos), in closed environments, or on smooth surfaces. The number of restrictions is so high that it outweighs the benefits.
In my night video, several people commented that the problem was because I was flying at night. But even during the day, the same issues occurred. I wonder: what will be the next excuse from DJI defenders?
When the red 'Fly with caution' message appears, the drone loses control shortly after.
9-16 02:04
LV_Forestry
Flight distance : 4726654 ft
Latvia
So far i have had no extreme issue like yours, even inside without GPS.
The main issue i had is drifting by night time, but its quite easy to keep manual control, and sudden change of position while in follow mode.
I would say its even feeling better with the last update.
Very pleasant drone for that price.
9-16 07:38
fichek
Flight distance : 1289590 ft
Croatia
Again, you're flying over a reflective surface which DJI explicitly tells you not to do. Visual positioning sensors get confused and crash. Operator error.
I do agree in general its vision positioning is really week and has surprised me by failing in some environments I would not consider too dark, but again, the manual does tell you to set your expectations low, and it *is* a cheap drone. You can always fly it in manual mode in these environments. Or try to cover bottom sensors and fly in atti mode from the start.
9-16 07:57
LV_Forestry
Latvia
fichek Posted at 9-16 07:57
Is there a way to disable these counterproductive protections?
This is my first time using DJI Fly
9-16 08:01
fichek
Croatia
LV_Forestry Posted at 9-16 08:01
Black tape over sensors on the bottom.
9-16 09:16
LV_Forestry
Latvia
fichek Posted at 9-16 09:16
I will try.
9-16 10:16
LV_Forestry
Latvia
False good advice.
It take off and climb out of control.
9-19 07:20
fichek
Croatia
LV_Forestry Posted at 9-19 07:20
False good advice.
sorry, I've seen someone in DJI Neo FB group do that and it looked pretty stable.
9-19 12:29
DJI Gamora
Hi there,
As mentioned on your previous thread on the same issue, please send the product for further testing by submitting an online repair request here: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. Thank you for your understanding and support.
9-19 20:37
DJI Gamora
LV_Forestry Posted at 9-16 07:38
Thank you for sharing your resolution. This sure will help other users whose having the same issue. Yes, While in N mode (Normal Mode) and S mode (Sports Mode), DJI Neo supports downward vision perception; while in M mode (Manual Mode), DJI Neo does not supports the perception feature. Have a safe flight always!
9-19 20:43
LV_Forestry
Latvia
DJI Gamora Posted at 9-19 20:43
It would be ideal to be able to access the M manual mode, including with the RC-N3, not just the FPV.
In autonomous mode (palm) it is understandable, but why have it locked with one RC and not the other?
Because on the N3 RC it is written C-N-S instead of C-M-S?
9-20 07:54
DJI Gamora
LV_Forestry Posted at 9-20 07:54
Hi LV_Forestry,
Could you please send us a video recording or footage of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
9-21 02:26
LV_Forestry
Latvia
DJI Gamora Posted at 9-21 02:26
Hi LV_Forestry,
You look at the first post of this thread, the video speaks for itself. I don't have such an extreme runaway phenomenon, but it's true that the downward sensor is sensitive and inaccurate. The drone moves by itself.
I completely understand the limitations of the sensor, moreover it works very well within the limits of what is defined in the manual.
All I ask would be to be able to simply deactivate it. with any RC, RC FPV, RCN3...
I come from the Enterprise range world, where everything can be deactivated via pilot 2. No matter what mode is selected. I'm sure it's possible to implement this with DJI Fly for the Consumer series as well.
9-21 04:11
Julian edwards
Brazil
Please, care to elaborate further?
I can only fly over water in manual mode with radio controller, and not with quick shots or wi-fi over a phone?
9-21 13:05
Antdrones
Flight distance : 1253035 ft
Julian edwards Posted at 9-21 13:05
You can fly over water with quickshots, but the drone might fly out of control
9-21 13:47
DJI Gamora
LV_Forestry Posted at 9-21 04:11
Hi there,
We are truly sorry for the inconvenience you are experiencing.
Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
9-22 02:53
DJI Gamora
Hi Julian,
Manual Mode is Classic FPV aircraft control mode with the highest maneuverability. In Manual mode, all flight assistance functions including precise hovering and auto-brake are disabled and proficient control skills are required. DJI Neo is light and compact we still do not recommend to fly over water as drifting may occur.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
9-22 03:12
FPVrider
Flight distance : 106516 ft
Switzerland
Jeferson, did you sent the drone for repair as DJI support has suggested?
Maybe there is really something wrong with our drones, so I would be interested if DJI was able to fix yours.
9-26 07:10
js349
Flight distance : 3675 ft
I have the same problem as what's in your video and I've noticed I can fly it in a hallway and certain rooms in my house all day long and it doesn't do that, but in certain areas in some rooms it just takes off forward out of control with that warning message. I'm using the Goggles 3 and the RC MC 3 and everything is on the latest firmware. I believe the places where it goes crazy have high wifi interference. Granted I'm not flying with my phone using wifi but I believe wifi interference could be the issue.
10-28 05:20
