DJI Gamora
djiuser_TL4mRrXk0FJs Posted at 9-19 03:28
Thanks. Neither works. My mobile is connected to home wifi. I open Fly. It says Firmware update is required. I click Install, it says - Failed, connect to device. I connect to device which opens the camera view. Now there is no way to start the update, so I go back to the homepage. It now says FlySafe requires update, I click Update, it says - Network required. But there's no network because I'm connected to the Neo. Disconnect the Neo, and nothing, dead-end.
DJI Assistant does nothing at-all. Doesn't even recognise anything is connected. It looks like it was for Windows XP or something.
Hi there,
DJI Assistant 2 (Consumer Drones Series) only support Windows Version V2.1.28 or Mac Version V2.1.28. To ensure compatibility, please check if your mobile device is listed on the DJI Fly app's supported devices list DJI Fly If your device is not compatible, try using one of the listed devices. If issue persist upon all the trial above please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You |
