[New Product Discussion] Be All In - Osmo Action 5 Pro
12Next >
4639 78 9-19 04:50
DJI Panda
Flight distance : 405039 ft
China
New Product Alert!!!
The Action Camera With Revolutionary Image Quality - Osmo Action 5 Pro
Join the discussion in the comments and share the feature you're most excited about.
Here are the six major highlights of the new Osmo Action 5 Pro.
Revolutionary Imaging Performance With an All-New 1/1.3″ Sensor
Our new sensor captures your best. From city nights to dramatic sunrises, get crystal-clear images with a 4nm chip. Experience vibrant imagery with 2.4 μm pixels and 13.5 stops of dynamic range, rivaling pro cameras.
Center and Track Subjects With Enhanced Precision
DJI brings subject tracking to an action camera. Action 5 Pro now intelligently detects the subject's position and dynamically adjusts the composition. Keep the subject centered in every frame, during horizontal or vertical shots.
Dual OLED High-Brightness Touchscreens
Catching the day's action? See it clearly thanks to the rear OLED screen's peak brightness now reaching a whopping 1000 nits. Make sure each shot has rich colors and high contrast with the front and rear OLED high-brightness touchscreens. The screens are larger with narrower bezels increasing the screen-to-body ratio by 16%.
Robust Stabilization With 360° HorizonSteady
HorizonSteady not only effectively reduces shakes but also corrects horizontal tilts within a 360° range, handling intense bumps and rotations effortlessly.
Capture More With 4hrs Extended Battery Life
We're setting a new benchmark for action camera battery performance. A single battery now delivers up to four hours of continuous use.  Never miss awesome with 50% more operating time compared to Action 4. Even in low-temperature conditions get up to 3.6 hours recording time at temperatures as low as -20° C.
Professional Audio Recording With DJI Microphone Connection
After connecting to the DJI Mic 2 Transmitter, Osmo Action 5 Pro can record at ultra-high sampling rates without needing a receiver. This ensures pristine, studio-quality sound while simplifying your gear setup and workflow. For dual-person vlogs or interviews, you can directly connect two transmitters to simultaneously capture both your and your partner's voices. Additionally, with Built-in Mic Audio Backup enabled, Action 5 Pro simultaneously records ambient sounds, adding a richer layer of authenticity to your video.
More surprises are in store!
Tell us the feature you're most excited about in the comment section.
9-19 04:50
Montfrooij
Flight distance : 2800262 ft
Nice.
The battery life looks very promising!
9-19 06:01
nachbelichtet
https://youtu.be/YcV-ODF7W94?t=107 Does this mean that you can now also use GPS telemetry data from a connected smartphone or a Garmin Watch?
9-19 06:06
Romild
Flight distance : 328510 ft
Denmark
Will the action 4 , battery and filters fit?
9-19 06:55
Uilleann Drone 1
Flight distance : 1127815 ft
Top bitrate 100Mbps??? that's a lot less than previous generations...
9-19 07:00
djiuser_OfkHCGDRUgoA
did they fix the voice commnd issue when in 4K and it is dissabled, unless you film in 2.7K?? Its disspointing when you need hands free (like Mtbing) to not be able to use 4K or not have voice command.
9-19 07:04
Pistolen33
Denmark
Uilleann Drone 1 Posted at 9-19 07:00
Thinking the same thing... Hopefully they can fix this with an update.
9-19 07:46
dfenton
I don't think they've fixed the horrible trumpet shaped lens flare from the Action 4. All cameras have lens flare but the shape of the one on the Action 4 could be very distracting. Not the case on the GoPro or even the Action 3. I think this issue still remains.
9-19 08:21
BaynhamPhoto
Flight distance : 427969 ft
Pistolen33 Posted at 9-19 07:46
That’s max bitrate I’ve seen one review comment 60mbs on file metadata
9-19 09:23
fansd5b682dd
Croatia
I ordered my 1st dji, hopefully i wont regreat it.
9-19 11:06
Ashton Horst
Battery life
9-19 12:23
DJI_user_PL3
Flight distance : 81345 ft
Poland
The same ugly sunflare as Action 4
9-19 12:45
djiuser_X8iGpOet8YTU
The battery life is crazy and I watched a video comparing to the new go pro and it’s much better in low light and generally looks better. Better dynamic range
9-19 13:31
BigDog816
Flight distance : 1800295 ft
I don't mind receiving emails from DJI, but I'm up to my 4th email today about Osmo, 1 in Chinese.
9-19 17:48
djiuser_VR5GBLl5PZDt
SOSOOSOSSOSKWOSOz
9-19 21:08
djiuser_4bzTCZa1tSAT
Indonesia
Anybody know if the battery case from osmo action 3 can charge the new battery from osmo action 5?
Because i see there is a new battery case on the website.
The old one doesn’t show it’s compatible with osmo action 5
9-20 04:37
djiuser_W0ffesOHIxuG
How to force a firmware update ?
9-20 07:30
RamblinMan
Flight distance : 592493 ft
I received my Osmo action five today. I am confused about emphasizing the bright screens when it comes to recording. From what I see the capability to leave the screen on during recording has been removed. The option of “never” has been removed when it comes to timing to turn screen off during recording.  Is that accurate?  Thanks.
9-20 15:05
djiuser_4SdfFMexnX8a
Does the lens unscrew on the action 5? For my action 4 filter.
9-20 17:20
Patrick O
Can this be operated remotely with an iPhone or external monitor?
9-21 03:57
djiuser_23rLcpY6c2N7
Greece
In bright areas has washed colors. Need a software update immediately
9-21 04:31
Micky FPV
Flight distance : 253832 ft
Bitrate needs to go up. At least as an option for people who want it. The new processor, sensor, spec and upgrades look great but this will be a no go if the bitrate issue is not addressed. There are some reviews that show some weird glow looking artefacts around some objects when filmed in auto, I assume this must be the “algorithm” trying to make up for the low bitrate, maybe?! This could be the deciding factor between the Action5 / GoPro 13.
9-21 05:35
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
China
Micky FPV Posted at 9-21 05:35
there is nothing to do with bitrate. image settings can be changed on action5pro : image adjustment- texture -2 to have a less enhanced look.
9-21 06:25
djiuser_m6EUHZKvujRM
I would love for DJI to make a dash cam.  I bet they’d knock it out of the park
9-21 07:47
Greece
Romild Posted at 9-19 06:55
Yes of course
9-21 09:38
fansee46d1e2
Flight distance : 5417 ft
THE BIT RATE SUCKS!!! Give us the option to customize it. This is phony as heck DJI.
9-21 13:32
djiuser_ObdUyJ9DwmE9
I just purchased the Action 5 Pro this week. Great camera.
One thing I noticed is that Voice Controls do not work on all resolutions. For example, in 4k30 the Start Recording command works but the Stop Recording does not work.
From what I read this problem has been around for a while. In the Action 5 Voice Commands work in 4k60 and 1080p30 but not 4k30 and 1080p60. I have not tested all resolutions.
It's surprising that DJI has not fixed this issue and made it available across all resolutions especially for a feature that is so widely used. Disappointed for such an expensive action camera.
9-21 18:49
djiuser_CPsOyUBLExhO
mine wont connect to PC (have had 2 Action 5 Pro now) all with same fault, Action 4 connect to PC instantly, Action 5 pro crashes PC and wont show
9-22 04:18
RamblinMan Posted at 9-20 15:05
it's an OLED screen, you DONT want it to burn..
9-22 04:32
RamblinMan
djiuser_CPsOyUBLExhO Posted at 9-22 04:32
iPhones have OLED screens and have a "never" option for turning off automatically.
9-22 07:42
djiuser_z7IDPeUw1ohI
Hi I am just shifting from GoPro and I observed this message “ Shooting complete, camera powering off, swipe up to continue” and get 3s timer. Is this default??
This is annoying how to disable this option if we have an option to do so. TIA
9-22 10:36
djiuser_TwM10B9wmmiD
Israel
We want magnetic charging cable to avoid open the door every time and risk the sealing of the camera .
It is must for surfing use.
If gopro can .... you can
9-22 12:34
AR Imagery
Flight distance : 5759623 ft
Montfrooij Posted at 9-19 06:01
Nice.
still wont let me have one to test...
9-22 23:48
Montfrooij
AR Imagery Posted at 9-22 23:48
I'm sure you will get one soon.
9-22 23:54
blocker87
If i connect bluetooth remote with action 4 and 5, the remote needs update every time? Very frustrating.
How to fix this
9-23 05:13
djiuser_YSelTOLHBQSX
Philippines
PLEASE DJI! BRING BACK the HIGH BITRATE(just like what’s in the Action 4
9-23 08:23
seany187
Can someone let me know if this supports RTMPS? I was thinking of purchasing for Game Changer. I have action cam 4 and it does not and I am not a fan of MEVO.
9-23 13:12
fans6abdbfe6
Received my A5 Pro today. So far so good. One feature I love is that I can use the quick capture and the Mic2 connects almost instantly. It took ages on the OA4.
I would love DJI to add the cancel recording like on the pocket 3. I make lots of mistakes and would like to be able to delete a clip by holding down the record button.
9-23 13:55
Ashton Horst
4 hr battery life
9-23 16:22
Ashton Horst
4 hr battery life
9-23 16:22
12Next >
