TB48 Battery Issues After Water Contact
1040 7 2015-9-22
ndamico1
Flight distance : 505889 ft
Hey Everyone,
Just a little backstory: I've been flying an Inspire 1 for a little while now and have been doing a lot of work over water. Unfortunately, this past weekend I had a little run in with a body of water.
If you'd like to see it, this is a goofy little edit I did for instagram: https://www.dropbox.com/s/e3krg595eopk252/DyersQuarryCrash.mp4?dl=0
So, basically I skimmed the water and the only parts that actually submerged were the camera and gimbal. I atleast pulled up in time to save the drone from a watery grave. I guess I got a little too cocky getting close to the water! Amazingly, after taking the necessary precautions to dry out the drone, the gimbal and camera are 100% working. My only issue is the battery. It didn't get submerged, but it obviously got splashed considering the circumstances. I just took it out for a quick low-altitude flight and there were no problems with the battery. Voltages were in the green and I noticed no problems. The only problem I'm seeing is the fact that I ran the battery down to 0% and for the last 20 minutes it's been sitting at 0% and STILL hasn't died. The DJI GO app is telling me theres 0mAh remaining. It also says I've charged the battery a total of 31 times. I think I've only charged it less than a dozen times. Should I consider it a goner before something catastrophic happens? Or once it fully cycles will it return to normal?
Any help would be appreciated.
Thanks!
Edit: As I wrote this, it finally died. Going to let it cool down and charge it back to 100%, unless I'm advised not to.
2015-9-22
ibdronin
Alright Maverick,  no more fly by's.
2015-9-22
ndamico1
Hahah ...
Yeah, I'm not proud of that one. Atleast the camera stayed on to get the footage so other people can laugh at my stupidity.
2015-9-22
joeyjoe
You're the luckiest Inspire 1 pilot I've seen yet and that is one cool video!
I would ditch the battery if I were you and be glad the whole episode only cost $200.
2015-9-22
ibdronin
If the battery just got splashed I'm not sure I would 86 it. Let it dry out for a couple days. You can always charge it put it back in and just hover a few feet from the ground and let the battery drain out and see how it goes. After all that's $200 but be safe and not fly far with it until you are certain.
2015-9-22
BoomStrike
Well that's one way to cool off the "Hot" camera! Lol
2015-9-22
g_audio
Thanks guys. I think I'm going to take my losses. The fact that the app is reporting that the battery has been charged 31 times concerns me. I should be able to return it, but it's quite the predicament. I originally ordered a TB47, but within the DJI battery box (which was labeled TB47) was a TB48. So, I feel like if I return it they're going to have a problem with the battery being different than the packaging. Karma for not reporting it, or returning it immediately, I guess.
2015-9-23
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
You should return the battery to DJI, maybe they will exchange it for a new one, its safer to lose USD200 than USD2,900 for the whole bird...
2015-9-23
