RC-N3 charging iPhone cannot be disable
3499 32 2024-9-24
djiuser_6h4lDXI54mLp
In the setting of RC-N3, already disabled Charing phone function but it still charging the iPhone. (Already latest firmware)
2024-9-24
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We apologize for the inconvenience. For the RC-N3, there is an option to turn on/off charging for the mobile phone. Please refer to the image below for the setting.
Since the issue persists even after you have disabled it, please record a video of the issue for further investigation. We appreciate your cooperation and kind understanding. Thank you.
2024-9-24
DJI Diana Posted at 9-24 00:36
Hi there,
I have already toggle to disable but the remote still charging my iphone
2024-9-24
DJI Diana
djiuser_6h4lDXI54mLp Posted at 9-24 00:38
Hi there.
We are checking with the relevant team on the matter, and we will update you once we receive the result. In the meantime, we recommend that you share a video demonstrating the issue you are experiencing. This way it will help us to analyze the situation better. Thank you.
2024-9-24
stonedmoe
Flight distance : 482923 ft
Brazil
Me too. My controller still charging my iPhone even if the option "Phone Charging" is disabled.
My controller battery lasting a little more of 1 hour and the probably cause is the charging that is not disabled.
2024-9-30
DJI Diana
Hi there,
We apologized for the delayed response. We recommend you try restarting the remote and DJI FLY after turning off the charging option, then you may check if the phone will still be charged or not. If the issue persists, please export the remote log via DA2 and share it here.
Looking forward to your response.
2024-10-12
djiuser_ws2vpDhFek1Q
Estonia
I have exactly the same problem! Just got my new dji neo fly more combo. I have restarted dji fly app (latest version), remote control and the drone, still the problem persist. Also all firmare is up to date. As I connect controller usb-c to phone it starts charging and doesn’t disable it even when in settings I have disabled phone charging. Disturbing, cause don’t waste the controller juice for fully charged iPhone… please fix that bug asap :/
2024-10-12
DJI Diana
djiuser_ws2vpDhFek1Q Posted at 10-12 14:48
Hi there,
Should the issue remain after restarting everything, kindly provide the information below for additional examination and analysis.
- [Remote Controller Log]
- [Date&Time]when this issue happened
- [Phone Model & OS version]
Please keep us updated on the progress.
2024-10-18
fansd2ec9037
DJI Diana Posted at 10-18 20:35
Hi there,
Same here I am having the same issues I tried restarting but still have the same issue. Any update on this when will it be fixed?? Currently using an iPhone 15 pro max.
2024-10-21
DJI Natalia
fansd2ec9037 Posted at 10-21 16:56
Hi there, thank you for reaching out and we do apologize for the trouble caused. May I confirm the exact DJI product you're using? Also, have you tried restarting the remote controller ? If you're using DJI RC-N3, kindly refer to comment #2 and try turn off the option for charging mobile phone.
Keep us posted the outcome and thank you for your understanding.
2024-10-22
fansd2ec9037
DJI Natalia Posted at 10-22 03:30
I am using a Dji Neo and yes I tried restarting the controller and everything you mentioned and still having the same issue!! When will this be fixed??
2024-10-22
DJI Natalia
fansd2ec9037 Posted at 10-22 04:23
Hi there, thank you for the response and we're sorry to hear that the issue still persist. Kindly share us the below informations for additional analysis and examination.
2024-10-22
Andrew Compton
Hello, I have the same issue with my iPhone 15 Pro Max while connecting to the RC-N3 every time I connect. I have toggled off the option multiple times, restarted the app, phone, and controller multiple times to no avail. Also, my controller refuses to connect to my PC to get a log using DA2. I've tried both USB-C ports on the controller and two different USB-C ports on my PC. I just want the controller to stop charging my phone. I'm also on the latest firmware. This seems to be a pretty widespread problem that needs to be addressed via firmware. From my research it appears that iPhones with lighting ports do not suffer from the issue but only newer iPhones with USB-C ports universally have the issue.
2024-10-29
LeOnBR
Flight distance : ****
Brazil
Andrew Compton Posted at 10-29 15:54
Indeed!
Same problem here with iPhone 16 Pro Max.
Waiting for the fix.
2024-11-9
DJI Diana
Hi there! Thank you for reaching out and we apologize for the inconvenience this has caused. We recommend you try restarting the remote and DJI FLY after turning off the charging option, then you may check if the phone will still be charged or not. If the issue persists, please export the remote log via DA2 and share it here and provide us the below details as well.
2024-11-9
Dano1642
Flight distance : 2136929 ft
My remote is doing the same thing. I used to get 7+ flights on a charge with my rcn2 and now I get less than 2 flights on my rcn3
2024-11-20
Keith-Nz
New Zealand
Can you turn it off on Android as will, I am having the same Problem with my cellphone..
2024-11-21
fans72bbc5fa
Hi DJI Diana... can you please stop asking people to send you useless reports and error logs about this issue and just let us know when It Will be fixed?? is just annoying, the controller battery gets wasted if you can not stop It from charging, It happens the same to Everyone!! just tell Your engineers to gran a bloody dron and rc-n3 and bloody test It and fix It!!
Many thanks!!
2024-12-4
djiuser_7ItKEjK72shc
Flight distance : 2155577 ft
Slovenia
I have the same problem.
I even dont have toggle to switch charging or not
2024-12-12
fans5dc4fd36
Flight distance : 185157 ft
Same problem here, this is nonesense, not only DJI took one of the batteries off the controller, so it lasts less than RC-N2, but to add insult to injury, phone charging cannot be disabled, obviously it is a bug, but a very nasty one. Now, the decision to lower the controller's battery capacity, is a brainfart, not a bug.
2024-12-12
Keith-Nz
New Zealand
yes it is and its the same for Android Phones to.
They told me that they will look into it,  and that was a while back now and still noting has been done about it..
2024-12-12
xradeon
Flight distance : 419308 ft
Mexico
I’m having the same issue with my neo and n3 controller with my iPhone 15 pro max. Charging the phone also produces more heat, so phone display is dim even sooner.
1-2 23:22
Keith-Nz
New Zealand
Thats the same for My Andriod phone (S24plus) I only get about 2 1/2 battery flights.
But noting been done about it yet..
1-2 23:59
fansf323bb7a
SO,,, nobody is going to take care of this DJI?
1-16 10:05
djiuser_rqGAnczQIJvU
Hello DJI Forum,
Is the phone charging issue from RC-N3 fixed with some updates?
I recently bought DJI Flip and facing similar issue with my iphone 15pro max.
Can you kindly let me know how to get this issue fixed?
1-31 01:18
DJI Natalia
djiuser_rqGAnczQIJvU Posted at 1-31 01:18
Hello DJI Forum,
Hi there, thank you for reaching out. May I confirm if the charging option has been turned off? If not, please refer to the comment #2 and turn off the option. if the issue still persists, kindly share us the following information;
- remote controller log
- date&time when the issue happened
- OS version.
Thank you!
1-31 03:38
djiuser_gywDrZXzWf1Z
Flight distance : 32864 ft
Switzerland
On Android it is not possible to "not charge" the phone while connected via USB-C by design
I suppose this is the reason there is no switch to turn it off in Fly app
(I do not have a iPhone and no knowledge about those)
1-31 04:36
Keith-Nz
New Zealand
DJI Natalia Posted at 1-31 03:38
The switch for the power on the cellphones should be on the RC-N3 controller End.
noting to do with the cellphones (iPhone/Android)
1-31 18:28
DJI Natalia
Keith-Nz Posted at 1-31 18:28
Thank you for your feedback. Since DJI RC -N3 does not have a built-in screen, you will need to use your mobile device to access the DJI Fly app and turn off/on the feature. Please rest assured that we will register your feedback and pass it on to the relevant departments for evaluation. We are committed to continuously optimizing and improving our product's compatibility features. For the latest updates, please stay tuned to our official website. Thank you for your understanding and support.
2-1 23:55
DJI Natalia
djiuser_gywDrZXzWf1Z Posted at 1-31 04:36
Hi there, thank you for your response. Yes, you are right. The "Phone Charging" feature is only available for iOS devices. I hope this information clarifies your concern. Thanks.
2-2 00:05
djiuser_kNa8mKWczAK8
Hallo
I just  think about buying a flip with RC 3N controller. Is this issue solved?
If not, how long will it take, assuming is still open for 6 month now.
Regards
Detlef
2-16 09:56
DJI Natalia
djiuser_kNa8mKWczAK8 Posted at 2-16 09:56
Hallo
Hi there, thank you for your interest with DJI Flip, and appreciate your inquiry. Unlike the previously released RC-N2/N1 remotes, the RC-N3 remote has upgraded to a new USB chip and low-power design, allowing for stable communication without supplying power when connected to most phone models. However, a few phone models do not support communication without power, so when connected to the remote, they will still receive slow USB charging to ensure a stable connection with the mobile device.
The previously released remotes, like the RC-N2/N1, required power when connecting to mobile devices to ensure stable communication, which is similar to how a phone receives slow charging when connected to a computer. Hope this answered your concern about the charging issue. Thank you for your understanding and support.
2-16 10:52
Mavic57Minis
Flight distance : 8923635 ft
Plenty of conversation over the years about this issue in all the forums where a phone is used in conjunction with a remote.
It will never be resolved.
2-16 11:43
