action 5 -apple health data
584 2 9-27 21:28
Dakis Kargios
Greece
After a lot of tries i can not import the health data from apple health to mimo app...I will be very thankfull if you guys help me with detail for the right way to do it
9-27 21:28
Vapors
Flight distance : 1883 ft
I have the same issue.  I start a bike workout and start a ride but every time I try to import the watch data it says there is No Matched Data.  Also I am using the remote and It has a GPS signal but still no route data is available.
9-28 13:12
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. May I confirm if you are able to access the data? If no please try the troubleshooting steps below;
1)[Confirm "Physical Training" Enabled] Prior to filming, kindly ensure that the relevant physical training, such as "outdoor cycling", has been correctly initiated. Verify that the corresponding sports data is visible in your fitness app to guarantee that the sports data has been accurately recorded.
[Confirm Device Time] Please check that the timestamp in the recorded sports data file of the relevant device encompasses the video shooting time to avoid potential issues stemming from unsynchronized device timing, which may result in video and data misalignment.
2) [Confirm Data Authorization Status] Please verify that the related sports data authorization has been completed, as failure to do so will result in the inability to access the corresponding dashboard sports data.
If the issue remains unresolved after performing the aforementioned operations, please refer to the "Procedure for Dealing with Abnormal Issues" for guidance.
If issue persist, please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering. We are looking forward to your response for further assistance. Thank You
9-29 00:27
