DJI Neo looses control at low light with Goggles 3
725 2 2024-10-9
FPVrider
Flight distance : 106516 ft
Switzerland
I analyzed with some better granularity the "out of control" issue with the DJI Neo:As background: I have all DJI FPV drones (FPV, Avata, Avata 2 and now the Neo).
I updated the Neo firmware to the latest version:
  • DJI Neo Firmware: V01.00.0300
which announced "Improved positioning performance", but this did not resolve the issue.
When I fly the Neo with my Goggles 3 and Motion Controller indoors (no GPS signal), I loose control every time the alarm about low light conditions comes up.
At the very moment when the Alarm is generated, the Neo starts accelerating forward and bumps into the next wall or object.
There is no time to react after the alarm is generated the drone is accelearting and any input from the motion controller is ignored.
Outside and with enough light the Neo flies perfectly and precise, with the Goggles it behaves just like my Avatas and I also notice no issues with the RC-N3 or mobile phone control.
I tested the same light conditions indoors with the RC N-3, with this controller the reaction is normal (as expected):
At the the same situation where I loose control with the Goggles, the DJI Fly App warns as well: "Insufficient light, Altitude Mode, Fly with Caution".
In "Altitude mode" the positioning is no longer perfect, the drone may drift a bit, but I still have full control to compensate these drifts, so it is no problem.
It also does not accelerate suddenly. There is time to land or even to navigate back to an area with better light.
I would expect the same behaviour also with the Goggles and Motion Controller, without camera positioning the drones could be less stable, OK, but I should still be able to compensate drifts with the controller. If this is not possible because of the different technology, in case of the alarm I would still prefer to freeze all controls or just land.
But accelerating is the worst possible option possible. This does absolutely feel like a failure, not the situation described in the manual.
To be clear, the situation when I get the alarm is by no means really "low light". I would describe it as typical daylight indoors when you are not immediately flying next to a window. To get an idea, if I switch on the electric lights, I do not notice a significant difference.
If this drone is supposed to to be usable for indoors flying it must absolutely be able to handle this amount of daylight
The bad behaviour with the goggles is abolutely reproducable and not acceptable. When people or valuable object are in the way, bad things could happen.
I am actually afraid now to fly the drone with goggles, even outdoors. I also do not recommed others to do so while the issue is not fixed.
I imagine a situation with "insufficient light" in the later afternoon, if there is no wall to bump against, nobody knows where the drone would be flying out of control...
2024-10-9
NeoNOOB
I just got my Neo + Goggles N3 in the past week. The uncontrollable low light acceleration has happened twice already. First while flying indoors I went into a darker room, the Neo blasted off straight into a wall. Then I was flying in the evening outdoors, prior to sunset. It was still very light outside, never would have suspected there would be an issue. My son was flying and said a warning popped up about flying safe, the Neo started flying erratically and was uncontrollable. It looked like maybe it was trying to land, but then it just took off and slammed into my neighbor's house. Based on all the other threads about this, flying in low light is absolutely an issue that needs a software fix. I can understand the limitation, but the behavior can not be to send the drone accelerating. I live next to a pond...this event was 20 ft from going for a swim!
3-13 07:50
DJI Gamora
NeoNOOB Posted at 3-13 07:50
Hi there, thank you for bringing this to our attention and we sincerely apologize for any inconvenience you may have experienced. If your aircraft has been involved in a collision or crash, it may have sustained structural or internal electronic damage, which could affect its flight safety and performance. As for your case, we recommend you send your aircraft back to DJI for a thorough diagnosis to mitigate any potential flight safety risks. Our dedicated team will meticulously inspect the aircraft to ensure its flight safety. You can submit a repair application via this link here : https://repair.dji.com/us/repair/index.
3 hours ago
