You sure can see all the critical info that you have mentioned and you also get a little diamond showing you were your home point is.If you get the headplays also get a lipo voltage monitor i got one of these adjustable ones you will need it as the headplay will switch off at 6volt.You get about an hour off one battery tho.Another thing is you just move the headplay up-to your forehead when you need or want to adjust other setting on your tablet.....Your gonna freaking love the h/p's youl never fly your bird again without em. http://www.ebay.com.au/itm/27125 ... =STRK%3AMEBIDX%3AIT
I use a HDMI to mini HDMI dongle (wire tied down) on both controller and HeadPlay (reduces wear on ports by plugging and unplugging all the time) and a standard HDMI cable 2m (6 feet) in length so a friend can use HP while I fly, here is one of my HP videos sitting in a chair to keep line of site, 3 miles out
Hi guys...
Does anyone have any simple setup documentation for the Headplay? Mine arrived today...the HDMI port will get here tomorrow.
In the meantime, where do you tuck the battery?
How to change the lens and add the foam pad?
