P3 Pro Issues (Firmware, no video signal, etc.)
1661 12 2015-9-24
justin.bregar
Flight distance : 19035 ft
I just got a P3 Pro that appears to be pretty old stock. Hooking it up to the DJI Go app for the first time, the gimbal activates then goes limp and the lights flash red, green, yellow (I think that's the sequence). There is also no video signal and the camera controls are all grayed out.
So, I figured I'd try to get it up to the latest firmware. Did the firmware update (figured I'd do 1.3.2 and then 1.4.10), but the firmware updates fail. Here are the relevant logs (this is long, I'm guessing the first firmware update 1.02.0006 was done at the factory?):
[00012333][01 00] Firmware upgrade finished successfully.
[00012440]Done.
[00012468]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x30a006ac].
[00012505]Version checking[2]...
[00012574][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012634][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012671][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012731][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012834][11 00][00] v1.6.0.0 -> v1.6.0.0
[00012914][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012989][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013069][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013149][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013287][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013363][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013483][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013527][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013556][01 00][05] v1.15.3056 -> v1.15.3056
[00013587][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade
[00013627][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013656]Done.
[00013687]Firmware upgrading[2]...
[00013835][01 01] Firmware upgrade start...
[00044098][01 01] Firmware upgrade finished successfully.
[00044159][17 00] Firmware upgrade start...
[00135865][17 00] Firmware upgrade finished successfully.
[00135909][17 01] Firmware upgrade start...
[00200651][17 01] Firmware upgrade finished successfully.
[00200701][03 05] Firmware upgrade start...
[00270995][03 05] Firmware upgrade finished successfully.
[00271220][03 06] Firmware upgrade start...
[00587550][03 06] Firmware upgrade finished successfully.
[00590443][19 00] Firmware upgrade start...
[00756865][19 00] Firmware upgrade finished successfully.
[00756924][04 00] Firmware upgrade start...
[00814231][04 00] Firmware upgrade finished successfully.
[00814264]Done.
[00814293]Version checking[3]...
[00814370][03 05][05] v34.2.0.9 -> v34.2.0.9
[00814450][03 06][05] v2.2.6.8 -> v2.2.6.8
[00814485][04 00][05] v1.38.0.0 -> v1.38.0.0
[00814532][09 00][00] v1.7.0.3 -> v1.7.0.3
[00814730][11 00][00] v1.6.0.0 -> v1.6.0.0
[00814827][12 00][00] v1.8.0.0 -> v1.8.0.0
[00814907][12 01][00] v1.8.0.0 -> v1.8.0.0
[00815005][12 02][00] v1.8.0.0 -> v1.8.0.0
[00815106][12 03][00] v1.8.0.0 -> v1.8.0.0
[00815249][15 00][00] v1.1.2.0 -> v1.1.2.0
[00815340][17 00][05] v1.1.1.6 -> v1.1.1.6
[00815461][17 01][05] v1.0.2.5 -> v1.0.2.5
[00815505][19 00][05] v1.0.8.96 -> v1.0.8.96
[00815543][01 00][05] v1.15.3056 -> v1.15.3056
[00815571][01 01][05] v1.15.3056 -> v1.15.3056
[00815615][08 00][00] v0.11.0.4 -> v0.11.0.4
[00815648]Packet upgrade finish successfully.
[00012433]========== remo-con disconnect. boot(15) ============
[00012471]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce57fd].
[00012503]Packet upgrade start...
[00012542]Packet checking...
[00012577]Done.
[00012613]Version checking[1]...
[00025151][03 05][00] device not detected.
[00037684][03 06][00] device not detected.
[00037733][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00050275][09 00][00] device not detected.
[00062809][11 00][00] device not detected.
[00075345][12 00][00] device not detected.
[00087876][12 01][00] device not detected.
[00100413][12 02][00] device not detected.
[00112947][12 03][00] device not detected.
[00115991][15 00][00] device not detected.
[00128530][17 00][00] device not detected.
[00141064][17 01][00] device not detected.
[00153602][19 00][00] device not detected.
[00153637][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00153669][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00161282][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00161315]Done.
[00163351]Waiting for user confirm...
[00173388]Timeout, start upgrade automatically.
[00173460]Firmware upgrading[1]...
[00185616][01 00] Firmware upgrade start...
[00014222][01 00] Firmware upgrade finished successfully.
[00014257]Done.
[00014297]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x90ce57fd].
[00014337]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014490]Version checking[2]...
[00027028][03 05][00] device not detected.
[00039562][03 06][00] device not detected.
[00039602][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00052145][09 00][00] device not detected.
[00064682][11 00][00] device not detected.
[00077221][12 00][00] device not detected.
[00089758][12 01][00] device not detected.
[00102292][12 02][00] device not detected.
[00114832][12 03][00] device not detected.
[00121577][15 00][00] device not detected.
[00134115][17 00][00] device not detected.
[00146649][17 01][00] device not detected.
[00159185][19 00][00] device not detected.
[00159219][01 00][05] v1.23.3419 -> v1.23.3419
[00159257][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00159302][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00159339]Done.
[00159373]Firmware upgrading[2]...
[00159523][01 01] Firmware upgrade start...
[00189788][01 01] Firmware upgrade finished successfully.
[00190649][08 00] Firmware upgrade start...
[00714996][08 00] Firmware upgrade finished successfully.
[00715059][04 00] Firmware upgrade start...
[00772447][04 00] Firmware upgrade finished successfully.
[00772485]Done.
[00772520]Version checking[3]...
[00785063][03 05][00] device not detected.
[00797598][03 06][00] device not detected.
[00797643][04 00][05] v1.40.0.0 -> v1.40.0.0
[00810177][09 00][00] device not detected.
[00822721][11 00][00] device not detected.
[00835261][12 00][00] device not detected.
[00847800][12 01][00] device not detected.
[00860336][12 02][00] device not detected.
[00872872][12 03][00] device not detected.
[00875908][15 00][00] device not detected.
[00888444][17 00][00] device not detected.
[00900993][17 01][00] device not detected.
[00913530][19 00][00] device not detected.
[00913561][01 00][05] v1.23.3419 -> v1.23.3419
[00913597][01 01][05] v1.23.3419 -> v1.23.3419
[00921283][08 00][05] v0.12.0.4 -> v0.12.0.4
[00921322]Packet upgrade failed at version checking.
[00012472]========== remo-con disconnect. boot(15) ============
[00012506]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce57fd].
[00012540]Packet upgrade start...
[00012578]Packet checking...
[00012621]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012684]Done.
[00012721]Version checking[1]...
[00025254][03 05][00] device not detected.
[00037791][03 06][00] device not detected.
[00037843][04 00][00] v1.40.0.0 -> v1.40.0.0
[00050380][09 00][00] device not detected.
[00062913][11 00][00] device not detected.
[00075452][12 00][00] device not detected.
[00088005][12 01][00] device not detected.
[00100546][12 02][00] device not detected.
[00113082][12 03][00] device not detected.
[00123874][15 00][00] device not detected.
[00136410][17 00][00] device not detected.
[00148946][17 01][00] device not detected.
[00161481][19 00][00] device not detected.
[00161519][01 00][00] v1.23.3419 -> v1.23.3419
[00161554][01 01][00] v1.23.3419 -> v1.23.3419
[00161603][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161637]Packet upgrade failed at version checking.
[00012474]========== remo-con disconnect. boot(15) ============
[00012506]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce57fd].
[00012541]Packet upgrade start...
[00012579]Packet checking...
[00012618]Packet vlink 01.01.0000 <-> 01.01.0000.
[00012680]Done.
[00012712]Version checking[1]...
[00025246][03 05][00] device not detected.
[00037786][03 06][00] device not detected.
[00037843][04 00][00] v1.40.0.0 -> v1.38.0.0
[00050374][09 00][00] device not detected.
[00062906][11 00][00] device not detected.
[00075442][12 00][00] device not detected.
[00087976][12 01][00] device not detected.
[00100515][12 02][00] device not detected.
[00113049][12 03][00] device not detected.
[00116069][15 00][00] device not detected.
[00128603][17 00][00] device not detected.
[00141136][17 01][00] device not detected.
[00153669][19 00][00] device not detected.
[00153702][01 00][00] v1.23.3419 -> v1.15.3056
[00153825][01 01][00] v1.23.3419 -> v1.15.3056
[00161472][08 00][00] v0.12.0.4 -> v0.11.0.4
[00161507]Packet upgrade failed at version checking.
[00012563]========== remo-con disconnect. boot(15) ============
[00012600]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x90ce57fd].
[00012639]Packet upgrade start...
[00012683]Packet checking...
[00012728]Packet vlink 01.01.0000 <-> 01.01.0000.
[00012796]Done.
[00012835]Version checking[1]...
[00025378][03 05][00] device not detected.
[00037917][03 06][00] device not detected.
[00037964][04 00][00] v1.40.0.0 -> v1.36.0.0
[00050504][09 00][00] device not detected.
[00063040][11 00][00] device not detected.
[00075575][12 00][00] device not detected.
[00088115][12 01][00] device not detected.
[00100653][12 02][00] device not detected.
[00113190][12 03][00] device not detected.
[00116265][15 00][00] device not detected.
[00128815][17 00][00] device not detected.
[00141354][17 01][00] device not detected.
[00153892][19 00][00] device not detected.
[00153931][01 00][00] v1.23.3419 -> v1.6.2736
[00153966][01 01][00] v1.23.3419 -> v1.5.2735
[00159023][08 00][00] v0.12.0.4 -> v0.11.0.4
[00159057]Packet upgrade failed at version checking.
[00013042]========== remo-con disconnect. boot(15) ============
[00013076]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xd0ce0053].
[00013110]Packet upgrade start...
[00013153]Packet checking...
[00013191]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013257]Done.
[00013290]Version checking[1]...
[00025832][03 05][00] device not detected.
[00038382][03 06][00] device not detected.
[00038429][04 00][00] v1.40.0.0 -> v1.40.0.0
[00050962][09 00][00] device not detected.
[00063498][11 00][00] device not detected.
[00076029][12 00][00] device not detected.
[00088563][12 01][00] device not detected.
[00101112][12 02][00] device not detected.
[00113648][12 03][00] device not detected.
[00118569][15 00][00] device not detected.
[00131182][17 00][00] device not detected.
[00143716][17 01][00] device not detected.
[00156252][19 00][00] device not detected.
[00156287][01 00][00] v1.23.3419 -> v1.23.3419
[00156324][01 01][00] v1.23.3419 -> v1.23.3419
[00161468][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161508]Packet upgrade failed at version checking.
[00012960]========== remo-con disconnect. boot(15) ============
[00012994]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xd0ce0053].
[00013031]Packet upgrade start...
[00013070]Packet checking...
[00013110]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013176]Done.
[00013211]Version checking[1]...
[00025747][03 05][00] device not detected.
[00038283][03 06][00] device not detected.
[00038329][04 00][00] v1.40.0.0 -> v1.40.0.0
[00050864][09 00][00] device not detected.
[00063400][11 00][00] device not detected.
[00075941][12 00][00] device not detected.
[00088476][12 01][00] device not detected.
[00101012][12 02][00] device not detected.
[00113550][12 03][00] device not detected.
[00118469][15 00][00] device not detected.
[00131004][17 00][00] device not detected.
[00143554][17 01][00] device not detected.
[00156090][19 00][00] device not detected.
[00156124][01 00][00] v1.23.3419 -> v1.23.3419
[00156157][01 01][00] v1.23.3419 -> v1.23.3419
[00161201][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161241]Packet upgrade failed at version checking.
[00013448]========== remo-con disconnect. boot(15) ============
[00013484]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xd0ce0053].
[00013517]Packet upgrade start...
[00013554]Packet checking...
[00013597]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013663]Done.
[00013697]Version checking[1]...
[00026235][03 05][00] device not detected.
[00038786][03 06][00] device not detected.
[00038840][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00051374][09 00][00] device not detected.
[00063908][11 00][00] device not detected.
[00076534][12 00][00] device not detected.
[00089068][12 01][00] device not detected.
[00101603][12 02][00] device not detected.
[00114142][12 03][00] device not detected.
[00120966][15 00][00] device not detected.
[00133502][17 00][00] device not detected.
[00146038][17 01][00] device not detected.
[00158576][19 00][00] device not detected.
[00158614][01 00][00] v1.23.3419 -> v1.23.3419
[00158648][01 01][00] v1.23.3419 -> v1.23.3419
[00161195][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161250]Done.
[00163285]Waiting for user confirm...
[00173319]Timeout, start upgrade automatically.
[00173393]Firmware upgrading[1]...
[00173464][04 00] Firmware upgrade start...
[00231464][04 00] Firmware upgrade finished successfully.
[00231501]Done.
[00231535]Version checking[2]...
[00244069][03 05][00] device not detected.
[00256605][03 06][00] device not detected.
[00256654][04 00][05] v1.41.0.0 -> v1.41.0.0
[00269189][09 00][00] device not detected.
[00281737][11 00][00] device not detected.
[00294273][12 00][00] device not detected.
[00306820][12 01][00] device not detected.
[00319362][12 02][00] device not detected.
[00331900][12 03][00] device not detected.
[00334829][15 00][00] device not detected.
[00347369][17 00][00] device not detected.
[00359902][17 01][00] device not detected.
[00372448][19 00][00] device not detected.
[00372484][01 00][00] v1.23.3419 -> v1.23.3419
[00372520][01 01][00] v1.23.3419 -> v1.23.3419
[00372577][08 00][00] v0.12.0.4 -> v0.12.0.4
[00372615]Packet upgrade failed at version checking.
That's a lot of "device not detected" messages. Is this thing screwed up? I can still send it back to the retailer.
2015-9-24
JtrJr-UAV Pilot
Flight distance : 4341 ft
Justin,
There have been a lot of various updates attempted with 3 different SD cards. Even 1.1.9 was attempted. Did you attempt all of these updates?
Jerry
2015-9-24
sploodge
Flight distance : 809350 ft
That's a lot of "device not detected".
Have a look at the little ribbon cabled linking the VPS to the gimbal and the gimbal to the Phantom 3.. See if its connected properly.. The logs seem to show its only seeing components on the gimbal ( not the vps and aircraft ).. Worth a check..
If you continue to have issues maybe contact the dealer you purchased from( or DJI direct if it came from them )..
2015-9-24
DJI-Tim
i think you need to contact our support to send it back Support.us@dji.com
2015-9-25
justin.bregar
The cable was loose. It was in there, so it looked ok but when I tapped it it fell loose meaning it probably wasn't connected at all.
After plugging it back in, the updates all worked perfectly.
2015-10-2
Xterminator.971
Hello little Justin.bregar you tell me which cable ? picture if posible !
[00054811]Delete history success.
[00055373]========== 2015.10.31 15:05:27. boot(15) ============
[00055444]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00055517]Packet upgrade start...
[00055596]Packet checking...
[00055671]Packet vlink 01.04.0010 <-> 01.03.0020.
[00055750]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00055822]Done.
[00055897]Version checking[1]...
[00056015][03 05][00] v34.2.0.9 -> v34.2.0.9
[00056122][03 06][00] v2.3.0.13 -> v2.3.0.13
[00056200][04 00][00] v1.41.0.0 -> v1.41.0.0
[00056302][09 00][00] v1.7.0.3 -> v1.7.0.3
[00056453][11 00][00] v1.7.0.0 -> v1.7.0.0
[00056584][12 00][00] v1.10.0.0 -> v1.10.0.0
[00056684][12 01][00] v1.10.0.0 -> v1.10.0.0
[00056831][12 02][00] v1.10.0.0 -> v1.10.0.0
[00056963][12 03][00] v1.10.0.0 -> v1.10.0.0
[00069536][15 00][00] device not detected.
[00069663][17 00][00] v1.1.1.7 -> v1.1.1.7
[00069840][17 01][00] v1.0.2.7 -> v1.0.2.7
[00069949][19 00][00] v1.0.8.96 -> v1.0.8.96
[00070023][01 00][00] v1.23.3419 -> v1.23.3419
[00070101][01 01][00] v1.23.3419 -> v1.23.3419
[00082678][08 00][00] device not detected.
[00082754]Packet upgrade failed at version checking.
[00014968]========== remo-con disconnect. boot(15) ============
[00015044]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00015114]Packet upgrade start...
[00015192]Packet checking...
[00015266]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015336]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015413]Done.
[00015482]Version checking[1]...
[00028058][03 05][00] device not detected.
[00040628][03 06][00] device not detected.
[00040716][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040814][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053395][11 00][00] device not detected.
[00065970][12 00][00] device not detected.
[00078544][12 01][00] device not detected.
[00091116][12 02][00] device not detected.
[00103688][12 03][00] device not detected.
[00116258][15 00][00] device not detected.
[00128939][17 00][00] device not detected.
[00141513][17 01][00] device not detected.
[00154086][19 00][00] device not detected.
[00154154][01 00][00] v1.23.3419 -> v1.23.3419
[00154226][01 01][00] v1.23.3419 -> v1.23.3419
[00166797][08 00][00] device not detected.
[00166874]Done.
[00168944]Waiting for user confirm...
[00179022]Timeout, start upgrade automatically.
[00179166]Firmware upgrading[1]...
[00179264][09 00] Firmware upgrade start...
[00229834][09 00] Firmware upgrade finished successfully.
[00229911]Done.
[00229982]Version checking[2]...
[00230106][03 05][00] v34.2.0.9 -> v34.2.0.9
[00230238][03 06][00] v2.3.0.13 -> v2.3.0.13
[00230315][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230409][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230572][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230719][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230835][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230954][12 02][00] v1.10.0.0 -> v1.10.0.0
[00231079][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243650][15 00][00] device not detected.
[00243775][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243935][17 01][00] v1.0.2.7 -> v1.0.2.7
[00244031][19 00][00] v1.0.8.96 -> v1.0.8.96
[00244106][01 00][00] v1.23.3419 -> v1.23.3419
[00244177][01 01][00] v1.23.3419 -> v1.23.3419
[00256746][08 00][00] device not detected.
[00256822]Packet upgrade failed at version checking.
[00014619]========== remo-con disconnect. boot(15) ============
[00014697]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014768]Packet upgrade start...
[00014848]Packet checking...
[00014922]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014997]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015069]Done.
[00015143]Version checking[1]...
[00027715][03 05][00] device not detected.
[00040285][03 06][00] device not detected.
[00040372][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040461][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053037][11 00][00] device not detected.
[00065607][12 00][00] device not detected.
[00078289][12 01][00] device not detected.
[00090869][12 02][00] device not detected.
[00103442][12 03][00] device not detected.
[00116011][15 00][00] device not detected.
[00128587][17 00][00] device not detected.
[00141158][17 01][00] device not detected.
[00153730][19 00][00] device not detected.
[00153805][01 00][00] v1.23.3419 -> v1.23.3419
[00153877][01 01][00] v1.23.3419 -> v1.23.3419
[00166452][08 00][00] device not detected.
[00166522]Done.
[00168593]Waiting for user confirm...
[00178669]Timeout, start upgrade automatically.
[00178817]Firmware upgrading[1]...
[00178908][09 00] Firmware upgrade start...
[00229322][09 00] Firmware upgrade finished successfully.
[00229401]Done.
[00229470]Version checking[2]...
[00229573][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229692][03 06][00] v2.3.0.13 -> v2.3.0.13
[00229776][04 00][00] v1.41.0.0 -> v1.41.0.0
[00229876][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230038][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230165][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230325][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230445][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230560][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243131][15 00][00] device not detected.
[00243240][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243400][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243496][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243571][01 00][00] v1.23.3419 -> v1.23.3419
[00243644][01 01][00] v1.23.3419 -> v1.23.3419
[00256220][08 00][00] device not detected.
[00256300]Packet upgrade failed at version checking.
[00014641]========== 2015.11.02 13:03:37. boot(15) ============
[00014712]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014787]Packet upgrade start...
[00014863]Packet checking...
[00014938]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015010]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015081]Done.
[00015157]Version checking[1]...
[00015288][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015406][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015570][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015662][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015807][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015939][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016056][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016181][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016341][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028914][15 00][00] device not detected.
[00029056][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029223][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029326][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029398][01 00][00] v1.23.3419 -> v1.23.3419
[00029473][01 01][00] v1.23.3419 -> v1.23.3419
[00042045][08 00][00] device not detected.
[00042114]Packet upgrade failed at version checking.
[00014780]========== remo-con disconnect. boot(15) ============
[00014854]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014926]Packet upgrade start...
[00015005]Packet checking...
[00015079]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015148]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015226]Done.
[00015296]Version checking[1]...
[00027872][03 05][00] device not detected.
[00040443][03 06][00] device not detected.
[00040527][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040615][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053193][11 00][00] device not detected.
[00065768][12 00][00] device not detected.
[00078340][12 01][00] device not detected.
[00090914][12 02][00] device not detected.
[00103485][12 03][00] device not detected.
[00116056][15 00][00] device not detected.
[00128631][17 00][00] device not detected.
[00141205][17 01][00] device not detected.
[00153774][19 00][00] device not detected.
[00153850][01 00][00] v1.23.3419 -> v1.23.3419
[00153920][01 01][00] v1.23.3419 -> v1.23.3419
[00166492][08 00][00] device not detected.
[00166563]Done.
[00168633]Waiting for user confirm...
[00178704]Timeout, start upgrade automatically.
[00178854]Firmware upgrading[1]...
[00178948][09 00] Firmware upgrade start...
[00229476][09 00] Firmware upgrade finished successfully.
[00229554]Done.
[00229625]Version checking[2]...
[00229728][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229834][03 06][00] v2.3.0.13 -> v2.3.0.13
[00229915][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230012][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230168][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230308][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230441][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230561][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230676][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243252][15 00][00] device not detected.
[00243352][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243532][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243632][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243703][01 00][00] v1.23.3419 -> v1.23.3419
[00243777][01 01][00] v1.23.3419 -> v1.23.3419
[00256346][08 00][00] device not detected.
[00256430]Packet upgrade failed at version checking.
[00014640]========== remo-con disconnect. boot(15) ============
[00014710]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014782]Packet upgrade start...
[00014858]Packet checking...
[00014932]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015006]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015079]Done.
[00015154]Version checking[1]...
[00015277][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015397][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015485][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015571][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015737][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015871][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016005][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016150][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016277][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028851][15 00][00] device not detected.
[00028986][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029142][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029238][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029312][01 00][00] v1.23.3419 -> v1.23.3419
[00029385][01 01][00] v1.23.3419 -> v1.23.3419
[00041955][08 00][00] device not detected.
[00042103]Packet upgrade failed at version checking.
[00014655]========== remo-con disconnect. boot(15) ============
[00014726]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014801]Packet upgrade start...
[00014877]Packet checking...
[00014955]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015026]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015097]Done.
[00015169]Version checking[1]...
[00027748][03 05][00] device not detected.
[00040320][03 06][00] device not detected.
[00040405][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040499][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053071][11 00][00] device not detected.
[00065639][12 00][00] device not detected.
[00078215][12 01][00] device not detected.
[00090792][12 02][00] device not detected.
[00103369][12 03][00] device not detected.
[00115939][15 00][00] device not detected.
[00128510][17 00][00] device not detected.
[00141085][17 01][00] device not detected.
[00153657][19 00][00] device not detected.
[00153727][01 00][00] v1.23.3419 -> v1.23.3419
[00153803][01 01][00] v1.23.3419 -> v1.23.3419
[00166372][08 00][00] device not detected.
[00166449]Done.
[00168517]Waiting for user confirm...
[00178588]Timeout, start upgrade automatically.
[00178735]Firmware upgrading[1]...
[00178830][09 00] Firmware upgrade start...
[00229240][09 00] Firmware upgrade finished successfully.
[00229314]Done.
[00229385]Version checking[2]...
[00229512][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229633][03 06][00] v2.3.0.13 -> v2.3.0.13
[00229714][04 00][00] v1.41.0.0 -> v1.41.0.0
[00229808][09 00][05] v1.7.0.3 -> v1.7.0.3
[00229973][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230108][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230241][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230367][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230502][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243073][15 00][00] device not detected.
[00243199][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243382][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243588][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243661][01 00][00] v1.23.3419 -> v1.23.3419
[00243733][01 01][00] v1.23.3419 -> v1.23.3419
[00256302][08 00][00] device not detected.
[00256379]Packet upgrade failed at version checking.
[00014630]========== 2015.11.02 14:11:37. boot(15) ============
[00014701]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014775]Packet upgrade start...
[00014856]Packet checking...
[00014934]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015005]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015081]Done.
[00015272][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015369][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015452][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015556][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015735][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015841][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015971][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016105][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016231][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028802][15 00][00] device not detected.
[00028939][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029100][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029185][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029261][01 00][00] v1.23.3419 -> v1.23.3419
[00029330][01 01][00] v1.23.3419 -> v1.23.3419
[00041907][08 00][00] device not detected.
[00041982]Packet upgrade failed at version checking.
[00015005]========== remo-con disconnect. boot(15) ============
[00015082]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x10ce148d].
[00015152]Packet upgrade start...
[00015233]Packet checking...
[00015306]Packet vlink 01.01.0000 <-> 01.01.0000.
[00015382]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).
[00015451]Packet upgrade failed at packet checking.
[00014636]========== remo-con disconnect. boot(15) ============
[00014707]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x10ce148d].
[00014773]Packet upgrade start...
[00014922]Packet checking...
[00014999]Packet vlink 01.01.0000 <-> 01.01.0000.
[00015071]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).
[00015145]Packet upgrade failed at packet checking.
[00014670]========== remo-con disconnect. boot(15) ============
[00014741]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x10ce148d].
[00014814]Packet upgrade start...
[00014893]Packet checking...
[00014968]Packet vlink 01.01.0000 <-> 01.01.0000.
[00015041]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).
[00015116]Packet upgrade failed at packet checking.
[00014765]========== remo-con disconnect. boot(15) ============
[00014838]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x10ce148d].
[00014909]Packet upgrade start...
[00014989]Packet checking...
[00015062]Packet vlink 01.01.0000 <-> 01.01.0000.
[00015138]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).
[00015208]Packet upgrade failed at packet checking.
[00014740]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014812]Packet upgrade start...
[00014890]Packet checking...
[00014967]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015039]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015110]Done.
[00015186]Version checking[1]...
[00027762][03 05][00] device not detected.
[00040335][03 06][00] device not detected.
[00040417][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[00040501][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053087][11 00][00] device not detected.
[00065660][12 00][00] device not detected.
[00078232][12 01][00] device not detected.
[00090803][12 02][00] device not detected.
[00103378][12 03][00] device not detected.
[00115953][15 00][00] device not detected.
[00128525][17 00][00] device not detected.
[00141102][17 01][00] device not detected.
[00153688][19 00][00] device not detected.
[00153760][01 00][00] v1.23.3419 -> v1.23.3419
[00153834][01 01][00] v1.23.3419 -> v1.23.3419
[00166522][08 00][00] device not detected.
[00166593]Done.
[00168671]Waiting for user confirm...
[00178746]Timeout, start upgrade automatically.
[00178892]Firmware upgrading[1]...
[00178991][09 00] Firmware upgrade start...
[00229403][09 00] Firmware upgrade finished successfully.
[00229505][04 00] Firmware upgrade start...
[00287571][04 00] Firmware upgrade finished successfully.
[00287648]Done.
[00287722]Version checking[2]...
[00287823][03 05][00] v34.2.0.9 -> v34.2.0.9
[00287922][03 06][00] v2.3.0.13 -> v2.2.6.19 need upgrade.
[00287998][04 00][05] v1.40.0.0 -> v1.40.0.0
[00288087][09 00][05] v1.7.0.3 -> v1.7.0.3
[00288238][11 00][00] v1.7.0.0 -> v1.7.0.0
[00288358][12 00][00] v1.10.0.0 -> v1.8.0.0
[00288467][12 01][00] v1.10.0.0 -> v1.8.0.0
[00288592][12 02][00] v1.10.0.0 -> v1.8.0.0
[00288712][12 03][00] v1.10.0.0 -> v1.8.0.0
[00301285][15 00][00] device not detected.
[00301387][17 00][00] v1.1.1.7 -> v1.1.1.7
[00301548][17 01][00] v1.0.2.7 -> v1.0.2.7
[00301649][19 00][00] v1.0.8.96 -> v1.0.8.96
[00301720][01 00][00] v1.23.3419 -> v1.23.3419
[00301794][01 01][00] v1.23.3419 -> v1.23.3419
[00314370][08 00][00] device not detected.
[00314448]Done.
[00314519]Firmware upgrading[2]...
[00314762][03 06] Firmware upgrade start...
[00344091][03 06] usb connected.
[00345813][03 06] usb connected.
[00373431][03 06] usb connected.
[00376015][03 06] usb connected.
[00378075][03 06] usb connected.
[00382171][03 06] usb connected.
[00386033][03 06] usb connected.
[00389754][03 06] usb connected.
[00392356][03 06] usb connected.
[00395260][03 06] usb connected.
[00397456][03 06] usb connected.
[00409914][03 06] usb connected.
[00412212][03 06] usb connected.
[00415615][03 06] usb connected.
[00417196][03 06] usb connected.
[00421815][03 06] usb connected.
[00430097][03 06] usb connected.
[00434998][03 06] usb connected.
[00436800][03 06] usb connected.
[00439597][03 06] usb connected.
[00451718][03 06] usb connected.
[00458218][03 06] usb connected.
[00460616][03 06] usb connected.
[00465516][03 06] usb connected.
[00468595][03 06] usb connected.
[00492378][03 06] usb connected.
[00504118][03 06] usb connected.
[00506160][03 06] usb connected.
[00508598][03 06] usb connected.
[00513161][03 06] usb connected.
[00520077][03 06] usb connected.
[00530779][03 06] usb connected.
[00534421][03 06] usb connected.
[00536340][03 06] usb connected.
[00540839][03 06] usb connected.
[00542943][03 06] usb connected.
[00545744][03 06] usb connected.
[00548340][03 06] usb connected.
[00551301][03 06] usb connected.
[00553759][03 06] usb connected.
[00576881][03 06] usb connected.
[00581044][03 06] usb connected.
[00589763][03 06] usb connected.
[00592353][03 06] usb connected.
[00629009][03 06] Firmware upgrade finished successfully.
[00629086]Done.
[00629154]Version checking[3]...
[00629274][03 05][00] v34.2.0.9 -> v34.2.0.9
[00629373][03 06][05] v2.2.6.19 -> v2.2.6.19
[00629450][04 00][05] v1.40.0.0 -> v1.40.0.0
[00629543][09 00][05] v1.7.0.3 -> v1.7.0.3
[00629699][11 00][00] v1.7.0.0 -> v1.7.0.0
[00629808][12 00][00] v1.10.0.0 -> v1.8.0.0
[00629924][12 01][00] v1.10.0.0 -> v1.8.0.0
[00630043][12 02][00] v1.10.0.0 -> v1.8.0.0
[00630168][12 03][00] v1.10.0.0 -> v1.8.0.0
[00642745][15 00][00] device not detected.
[00642864][17 00][00] v1.1.1.7 -> v1.1.1.7
[00643040][17 01][00] v1.0.2.7 -> v1.0.2.7
[00643124][19 00][00] v1.0.8.96 -> v1.0.8.96
[00643199][01 00][00] v1.23.3419 -> v1.23.3419
[00643269][01 01][00] v1.23.3419 -> v1.23.3419
[00655842][08 00][00] device not detected.
[00655919]Packet upgrade failed at version checking.
[00014639]========== remo-con disconnect. boot(15) ============
[00014707]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014783]Packet upgrade start...
[00014932]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015007]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015149]Done.
[00015223]Version checking[1]...
[00015333][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015433][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015514][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015602][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015748][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015878][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016002][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016123][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016249][12 03][00] v1.10.0.0 -> v1.8.0.0
[00014663]========== 2015.11.02 14:33:56. boot(15) ============
[00014739]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014808]Packet upgrade start...
[00014887]Packet checking...
[00014961]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015031]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015107]Done.
[00015176]Version checking[1]...
[00015316][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015435][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015513][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015610][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015775][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015910][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016031][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016165][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016325][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028899][15 00][00] device not detected.
[00029023][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029197][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029274][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029344][01 00][00] v1.23.3419 -> v1.23.3419
[00029415][01 01][00] v1.23.3419 -> v1.23.3419
[00041981][08 00][00] device not detected.
[00042047]Packet upgrade failed at version checking.
[00014667]========== remo-con disconnect. boot(15) ============
[00014743]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014966]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015042]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015114]Done.
[00015411][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015530][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015611][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015704][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015870][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015985][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016104][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016225][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016355][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028931][15 00][00] device not detected.
[00029041][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029200][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029285][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029358][01 00][00] v1.23.3419 -> v1.23.3419
[00029431][01 01][00] v1.23.3419 -> v1.23.3419
[00042011][08 00][00] device not detected.
[00042082]Packet upgrade failed at version checking.
[00014681]========== remo-con disconnect. boot(15) ============
[00014755]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014834]Packet upgrade start...
[00014912]Packet checking...
[00014992]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015066]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015166]Done.
[00015241]Version checking[1]...
[00015340][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015456][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00015535][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015625][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015912][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016031][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016155][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016290][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028864][15 00][00] device not detected.
[00028981][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029147][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029247][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029325][01 00][00] v1.23.3419 -> v1.23.3419
[00029395][01 01][00] v1.23.3419 -> v1.23.3419
[00041975][08 00][00] device not detected.
[00042050]Done.
[00044123]Waiting for user confirm...
[00054283]Timeout, start upgrade automatically.
[00054436]Firmware upgrading[1]...
[00054690][03 06] Firmware upgrade start...
[00401864][03 06] Firmware upgrade finished successfully.
[00401968][04 00] Firmware upgrade start...
[00460856][04 00] Firmware upgrade finished successfully.
[00460929]Done.
[00461005]Version checking[2]...
[00461118][03 05][00] v34.2.0.9 -> v34.2.0.9
[00461218][03 06][05] v2.3.0.13 -> v2.3.0.13
[00461294][04 00][05] v1.41.0.0 -> v1.41.0.0
[00461387][09 00][00] v1.7.0.3 -> v1.7.0.3
[00461537][11 00][00] v1.7.0.0 -> v1.7.0.0
[00461666][12 00][00] v1.10.0.0 -> v1.10.0.0
[00461795][12 01][00] v1.10.0.0 -> v1.10.0.0
[00461926][12 02][00] v1.10.0.0 -> v1.10.0.0
[00462046][12 03][00] v1.10.0.0 -> v1.10.0.0
[00474620][15 00][00] device not detected.
[00474724][17 00][00] v1.1.1.7 -> v1.1.1.7
[00474864][17 01][00] v1.0.2.7 -> v1.0.2.7
[00474949][19 00][00] v1.0.8.96 -> v1.0.8.96
[00475028][01 00][00] v1.23.3419 -> v1.23.3419
[00475101][01 01][00] v1.23.3419 -> v1.23.3419
[00487675][08 00][00] device not detected.
[00487750]Packet upgrade failed at version checking.
[00014691]========== remo-con disconnect. boot(15) ============
[00014765]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014846]Packet upgrade start...
[00014921]Packet checking...
[00014999]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015075]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015151]Done.
[00015224]Version checking[1]...
[00027801][03 05][00] device not detected.
[00040377][03 06][00] device not detected.
[00040466][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040553][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053126][11 00][00] device not detected.
[00065701][12 00][00] device not detected.
[00078280][12 01][00] device not detected.
[00090853][12 02][00] device not detected.
[00103439][12 03][00] device not detected.
[00116014][15 00][00] device not detected.
[00128593][17 00][00] device not detected.
[00141275][17 01][00] device not detected.
[00153852][19 00][00] device not detected.
[00153925][01 00][00] v1.23.3419 -> v1.23.3419
[00154003][01 01][00] v1.23.3419 -> v1.23.3419
[00166577][08 00][00] device not detected.
[00166650]Done.
[00168729]Waiting for user confirm...
[00178800]Timeout, start upgrade automatically.
[00178951]Firmware upgrading[1]...
[00179051][09 00] Firmware upgrade start...
[00229573][09 00] Firmware upgrade finished successfully.
[00229653]Done.
[00229728]Version checking[2]...
[00229852][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229971][03 06][00] v2.3.0.13 -> v2.3.0.13
[00230055][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230151][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230352][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230484][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230604][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230740][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230866][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243441][15 00][00] device not detected.
[00243561][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243721][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243813][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243887][01 00][00] v1.23.3419 -> v1.23.3419
[00243961][01 01][00] v1.23.3419 -> v1.23.3419
[00256539][08 00][00] device not detected.
[00256613]Packet upgrade failed at version checking.
[00014712]========== remo-con disconnect. boot(15) ============
[00014789]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014868]Packet upgrade start...
[00014951]Packet checking...
[00015028]Packet vlink 01.04.0010 <-> 01.03.0020.
cket [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d] [00014705]========== remo-con disconnect. boot(15) ============
[00014782]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014855]Packet upgrade start...
[00014935]Packet checking...
[00015014]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015092]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015168]Done.
[00015244]Version checking[1]...
[00015466][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015584][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015673][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015758][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015925][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016052][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016198][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016357][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016492][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014696]========== remo-con disconnect. boot(15) ============
[00014773]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014849]Packet upgrade start...
[00014931]Packet checking...
[00015009]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015087]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015164]Done.
[00015239]Version checking[1]...
[00027815][03 05][00] device not detected.
[00040392][03 06][00] device not detected.
[00040481][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040565][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053142][11 00][00] device not detected.
[00065721][12 00][00] device not detected.
[00078295][12 01][00] device not detected.
[00090872][12 02][00] device not detected.
[00103453][12 03][00] device not detected.
[00116028][15 00][00] device not detected.
[00128607][17 00][00] device not detected.
[00141190][17 01][00] device not detected.
[00153766][19 00][00] device not detected.
[00153844][01 00][00] v1.23.3419 -> v1.23.3419
[00153924][01 01][00] v1.23.3419 -> v1.23.3419
[00166497][08 00][00] device not detected.
[00166573]Done.
[00168650]Waiting for user confirm...
[00178729]Timeout, start upgrade automatically.
[00178880]Firmware upgrading[1]...
[00178978][09 00] Firmware upgrade start...
[00229545][09 00] Firmware upgrade finished successfully.
[00229625]Done.
[00229697]Version checking[2]...
[00229824][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229919][03 06][00] v2.3.0.13 -> v2.3.0.13
[00229998][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230113][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230399][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230528][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230653][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230773][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230889][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243467][15 00][00] device not detected.
[00243589][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243744][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243849][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243927][01 00][00] v1.23.3419 -> v1.23.3419
[00244001][01 01][00] v1.23.3419 -> v1.23.3419
[00256579][08 00][00] device not detected.
[00256657]Packet upgrade failed at version checking.
[00014790]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014867]Packet upgrade start...
[00014949]Packet checking...
[00015026]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015103]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015179]Done.
[00015257]Version checking[1]...
[00027832][03 05][00] device not detected.
[00040409][03 06][00] device not detected.
[00040502][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040591][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053166][11 00][00] device not detected.
[00065744][12 00][00] device not detected.
[00078321][12 01][00] device not detected.
[00090894][12 02][00] device not detected.
[00103473][12 03][00] device not detected.
[00116050][15 00][00] device not detected.
[00128623][17 00][00] device not detected.
[00141197][17 01][00] device not detected.
[00153788][19 00][00] device not detected.
[00153862][01 00][00] v1.23.3419 -> v1.23.3419
[00153939][01 01][00] v1.23.3419 -> v1.23.3419
[00166520][08 00][00] device not detected.
[00166594]Done.
[00168673]Waiting for user confirm...
[00178749]Timeout, start upgrade automatically.
[00178900]Firmware upgrading[1]...
[00178996][09 00] Firmware upgrade start...
[00229515][09 00] Firmware upgrade finished successfully.
[00229594]Done.
[00229670]Version checking[2]...
[00229870][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229964][03 06][00] v2.3.0.13 -> v2.3.0.13
[00230049][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230153][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230365][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230478][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230738][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230858][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243440][15 00][00] device not detected.
[00243554][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243714][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243814][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243891][01 00][00] v1.23.3419 -> v1.23.3419
[00243967][01 01][00] v1.23.3419 -> v1.23.3419
[00256543][08 00][00] device not detected.
[00256622]Packet upgrade failed at version checking.
[00014709]========== remo-con disconnect. boot(15) ============
[00014781]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014860]Packet upgrade start...
[00014937]Packet checking...
[00015015]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015169]Done.
[00015249]Version checking[1]...
[00027822][03 05][00] device not detected.
[00040396][03 06][00] device not detected.
[00040490][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040582][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053156][11 00][00] device not detected.
[00065734][12 00][00] device not detected.
[00078312][12 01][00] device not detected.
[00090888][12 02][00] device not detected.
[00103467][12 03][00] device not detected.
[00128625][17 00][00] device not detected.
[00153863][01 00][00] v1.23.3419 -> v1.23.3419
[00153940][01 01][00] v1.23.3419 -> v1.23.3419
[00166593]Done.
[00168665]Waiting for user confirm...
[00178743]Timeout, start upgrade automatically.
[00179001]Firmware upgrading[1]...
[00179098][09 00] Firmware upgrade start...
[00229521][09 00] Firmware upgrade finished successfully.
[00229601]Done.
[00229678]Version checking[2]...
[00229793][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229917][03 06][00] v2.3.0.13 -> v2.3.0.13
[00230003][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230112][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230273][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230427][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230572][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230706][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230852][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243430][15 00][00] device not detected.
[00243563][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243747][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243853][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243930][01 00][00] v1.23.3419 -> v1.23.3419
[00244008][01 01][00] v1.23.3419 -> v1.23.3419
[00256590][08 00][00] device not detected.
[00256666]Packet upgrade failed at version checking.
[00114599]========== 2015.11.05 14:33:52. boot(15) ============
[00114671]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00114748]Packet upgrade start...
[00114822]Packet checking...
[00114899]Packet vlink 01.04.0010 <-> 01.03.0020.
[00114973]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00115048]Done.
[00115119]Version checking[1]...
[00115243][03 05][00] v34.2.0.9 -> v34.2.0.9
[00115344][03 06][00] v2.3.0.13 -> v2.3.0.13
[00115421][04 00][00] v1.41.0.0 -> v1.41.0.0
[00115512][09 00][00] v1.7.0.3 -> v1.7.0.3
[00115664][11 00][00] v1.7.0.0 -> v1.7.0.0
[00115804][12 00][00] v1.10.0.0 -> v1.10.0.0
[00115912][12 01][00] v1.10.0.0 -> v1.10.0.0
[00116042][12 02][00] v1.10.0.0 -> v1.10.0.0
[00116165][12 03][00] v1.10.0.0 -> v1.10.0.0
[00128735][15 00][00] device not detected.
[00128848][17 00][00] v1.1.1.7 -> v1.1.1.7
[00129040][17 01][00] v1.0.2.7 -> v1.0.2.7
[00129132][19 00][00] v1.0.8.96 -> v1.0.8.96
[00129207][01 00][00] v1.23.3419 -> v1.23.3419
[00129359][01 01][00] v1.23.3419 -> v1.23.3419
[00141934][08 00][00] device not detected.
[00142007]Packet upgrade failed at version checking.
[00068660]========== 2015.11.05 14:37:23. boot(15) ============
[00068735]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00068810]Packet upgrade start...
[00068886]Packet checking...
[00068959]Packet vlink 01.04.0010 <-> 01.03.0020.
[00069035]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00069110]Done.
[00069183]Version checking[1]...
[00069307][03 05][00] v34.2.0.9 -> v34.2.0.9
[00069427][03 06][00] v2.3.0.13 -> v2.3.0.13
[00069507][04 00][00] v1.41.0.0 -> v1.41.0.0
[00069604][09 00][00] v1.7.0.3 -> v1.7.0.3
[00069762][11 00][00] v1.7.0.0 -> v1.7.0.0
[00069899][12 00][00] v1.10.0.0 -> v1.10.0.0
[00070042][12 01][00] v1.10.0.0 -> v1.10.0.0
[00070179][12 02][00] v1.10.0.0 -> v1.10.0.0
[00070327][12 03][00] v1.10.0.0 -> v1.10.0.0
[00082909][15 00][00] device not detected.
[00083030][17 00][00] v1.1.1.7 -> v1.1.1.7
[00083192][17 01][00] v1.0.2.7 -> v1.0.2.7
[00083277][19 00][00] v1.0.8.96 -> v1.0.8.96
[00083354][01 00][00] v1.23.3419 -> v1.23.3419
[00083429][01 01][00] v1.23.3419 -> v1.23.3419
[00096000][08 00][00] device not detected.
[00096075]Packet upgrade failed at version checking.
[00420971]========== 2015.11.05 15:38:45. boot(15) ============
[00421048]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00421124]Packet upgrade start...
[00421205]Packet checking...
[00421285]Packet vlink 01.03.0020 <-> 01.01.0009.
[00421363]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00421443]Done.
[00421519]Version checking[1]...
[00421635][03 05][00] v34.2.0.9 -> v34.2.0.9
[00421735][03 06][00] v2.3.0.13 -> v2.2.6.19 need upgrade.
[00421822][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[00421924][09 00][00] v1.7.0.3 -> v1.7.0.3
[00422077][11 00][00] v1.7.0.0 -> v1.7.0.0
[00422223][12 00][00] v1.10.0.0 -> v1.8.0.0
[00422344][12 01][00] v1.10.0.0 -> v1.8.0.0
[00422587][12 02][00] v1.10.0.0 -> v1.8.0.0
[00422704][12 03][00] v1.10.0.0 -> v1.8.0.0
[00435287][15 00][00] device not detected.
[00435424][17 00][00] v1.1.1.7 -> v1.1.1.7
[00435584][17 01][00] v1.0.2.7 -> v1.0.2.7
[00435670][19 00][00] v1.0.8.96 -> v1.0.8.96
[00435749][01 00][00] v1.23.3419 -> v1.23.3419
[00435824][01 01][00] v1.23.3419 -> v1.23.3419
[00448408][08 00][00] device not detected.
[00448482]Done.
[00450556]Waiting for user confirm...
[00460635]Timeout, start upgrade automatically.
[00460789]Firmware upgrading[1]...
[00461030][03 06] Firmware upgrade start...
[00789669][03 06] Firmware upgrade finished successfully.
[00789771][04 00] Firmware upgrade start...
[00847740][04 00] Firmware upgrade finished successfully.
[00847819]Done.
[00847894]Version checking[2]...
[00848008][03 05][00] v34.2.0.9 -> v34.2.0.9
[00848107][03 06][05] v2.2.6.19 -> v2.2.6.19
[00848229][04 00][05] v1.40.0.0 -> v1.40.0.0
[00848318][09 00][00] v1.7.0.3 -> v1.7.0.3
[00848663][11 00][00] v1.7.0.0 -> v1.7.0.0
[00848783][12 00][00] v1.10.0.0 -> v1.8.0.0
[00848897][12 01][00] v1.10.0.0 -> v1.8.0.0
[00849017][12 02][00] v1.10.0.0 -> v1.8.0.0
[00849142][12 03][00] v1.10.0.0 -> v1.8.0.0
[00861718][15 00][00] device not detected.
[00861833][17 00][00] v1.1.1.7 -> v1.1.1.7
[00861993][17 01][00] v1.0.2.7 -> v1.0.2.7
[00862098][19 00][00] v1.0.8.96 -> v1.0.8.96
[00862184][01 00][00] v1.23.3419 -> v1.23.3419
[00862257][01 01][00] v1.23.3419 -> v1.23.3419
[00874837][08 00][00] device not detected.
[00874909]Packet upgrade failed at version checking.
[00014778]========== 2015.11.05 15:46:55. boot(15) ============
[00014852]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00015010]Packet checking...
[00015087]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015164]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015241]Done.
[00015318]Version checking[1]...
[00015547][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015665][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015747][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015850][09 00][00] v1.7.0.3 -> v1.7.0.3
[00330783]========== 2015.11.05 15:59:04. boot(15) ============
[00330859]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00330935]Packet upgrade start...
[00331022]Packet checking...
[00331099]Packet vlink 01.03.0020 <-> 01.01.0009.
[00331181]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00331256]Done.
[00331339]Version checking[1]...
[00331461][03 05][00] v34.2.0.9 -> v34.2.0.9
[00331576][03 06][00] v2.2.6.19 -> v2.2.6.19
[00331667][04 00][00] v1.40.0.0 -> v1.40.0.0
[00331756][09 00][00] v1.7.0.3 -> v1.7.0.3
[00331915][11 00][00] v1.7.0.0 -> v1.7.0.0
[00332057][12 00][00] v1.10.0.0 -> v1.8.0.0
[00332190][12 01][00] v1.10.0.0 -> v1.8.0.0
[00332345][12 02][00] v1.10.0.0 -> v1.8.0.0
[00332470][12 03][00] v1.10.0.0 -> v1.8.0.0
[00345050][15 00][00] device not detected.
[00345162][17 00][00] v1.1.1.7 -> v1.1.1.7
[00345326][17 01][00] v1.0.2.7 -> v1.0.2.7
[00345416][19 00][00] v1.0.8.96 -> v1.0.8.96
[00345490][01 00][00] v1.23.3419 -> v1.23.3419
[00345558][01 01][00] v1.23.3419 -> v1.23.3419
[00358137][08 00][00] device not detected.
[00358205]Packet upgrade failed at version checking.
[00014766]========== remo-con disconnect. boot(15) ============
[00014841]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014914]Packet upgrade start...
[00014998]Packet checking...
[00015071]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015150]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015223]Done.
[00015304]Version checking[1]...
[00015396][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015516][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015595][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015696][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015857][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015966][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016094][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016328][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016510][12 03][00] v1.10.0.0 -> v1.8.0.0
[00029085][15 00][00] device not detected.
[00029207][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029386][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029482][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029556][01 00][00] v1.23.3419 -> v1.23.3419
[00029634][01 01][00] v1.23.3419 -> v1.23.3419
[00042209][08 00][00] device not detected.
[00042288]Packet upgrade failed at version checking.
[00014760]========== remo-con disconnect. boot(15) ============
[00014916]Packet upgrade start...
[00015001]Packet checking...
[00015075]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015156]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015231]Done.
[00015311]Version checking[1]...
[00027887][03 05][00] device not detected.
[00040470][03 06][00] device not detected.
[00040555][04 00][00] v1.40.0.0 -> v1.40.0.0
[00040651][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053225][11 00][00] device not detected.
[00065798][12 00][00] device not detected.
[00078376][12 01][00] device not detected.
[00090952][12 02][00] device not detected.
[00103533][12 03][00] device not detected.
[00116108][15 00][00] device not detected.
[00128687][17 00][00] device not detected.
[00141266][17 01][00] device not detected.
[00153843][19 00][00] device not detected.
[00153921][01 00][00] v1.23.3419 -> v1.23.3419
[00153995][01 01][00] v1.23.3419 -> v1.23.3419
[00166569][08 00][00] device not detected.
[00166648]Done.
[00168722]Waiting for user confirm...
[00178798]Timeout, start upgrade automatically.
[00179047][09 00] Firmware upgrade start...
[00229472][09 00] Firmware upgrade finished successfully.
[00229551]Done.
[00229626]Version checking[2]...
[00229731][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229832][03 06][00] v2.2.6.19 -> v2.2.6.19
[00230023][04 00][00] v1.40.0.0 -> v1.40.0.0
[00230122][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230270][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230380][12 00][00] v1.10.0.0 -> v1.8.0.0
[00230505][12 01][00] v1.10.0.0 -> v1.8.0.0
[00230625][12 02][00] v1.10.0.0 -> v1.8.0.0
[00230736][12 03][00] v1.10.0.0 -> v1.8.0.0
[00243309][15 00][00] device not detected.
[00243419][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243581][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243677][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243751][01 00][00] v1.23.3419 -> v1.23.3419
[00243827][01 01][00] v1.23.3419 -> v1.23.3419
[00256402][08 00][00] device not detected.
[00256479]Packet upgrade failed at version checking.
[00014925]========== remo-con disconnect. boot(15) ============
[00015002]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00015075]Packet upgrade start...
[00015151]Packet checking...
[00015225]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015297]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015373]Done.
[00015446]Version checking[1]...
[00028023][03 05][00] device not detected.
[00040596][03 06][00] device not detected.
[00040691][04 00][00] v1.40.0.0 -> v1.40.0.0
[00040782][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053366][11 00][00] device not detected.
[00065940][12 00][00] device not detected.
[00078514][12 01][00] device not detected.
[00091091][12 02][00] device not detected.
[00103661][12 03][00] device not detected.
[00116233][15 00][00] device not detected.
[00128808][17 00][00] device not detected.
[00141382][17 01][00] device not detected.
[00153966][19 00][00] device not detected.
[00154040][01 00][00] v1.23.3419 -> v1.23.3419
[00154110][01 01][00] v1.23.3419 -> v1.23.3419
[00166687][08 00][00] device not detected.
[00166757]Done.
[00168834]Waiting for user confirm...
[00178904]Timeout, start upgrade automatically.
[00179053]Firmware upgrading[1]...
[00179144][09 00] Firmware upgrade start...
[00229578][09 00] Firmware upgrade finished successfully.
[00229729]Done.
[00229800]Version checking[2]...
[00229922][03 05][00] v34.2.0.9 -> v34.2.0.9
[00230043][03 06][00] v2.2.6.19 -> v2.2.6.19
[00230120][04 00][00] v1.40.0.0 -> v1.40.0.0
[00230209][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230359][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230533][12 00][00] v1.10.0.0 -> v1.8.0.0
[00230658][12 01][00] v1.10.0.0 -> v1.8.0.0
[00230778][12 02][00] v1.10.0.0 -> v1.8.0.0
[00230888][12 03][00] v1.10.0.0 -> v1.8.0.0
[00243459][15 00][00] device not detected.
[00243568][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243733][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243828][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243904][01 00][00] v1.23.3419 -> v1.23.3419
[00243976][01 01][00] v1.23.3419 -> v1.23.3419
[00256548][08 00][00] device not detected.
[00256624]Packet upgrade failed at version checking.
[00014773]========== 2015.11.05 16:37:12. boot(15) ============
[00014850]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x10ce148d].
[00014919]Packet upgrade start...
[00014995]Packet checking...
[00015070]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015145]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015217]Done.
[00015286]Version checking[1]...
[00015382][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015502][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015581][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015692][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015848][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015962][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016074][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016198][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016332][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028903][15 00][00] device not detected.
[00029011][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029171][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029276][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029351][01 00][00] v1.23.3419 -> v1.23.3419
[00029424][01 01][00] v1.23.3419 -> v1.23.3419
[00041999][08 00][00] device not detected.
[00042072]Packet upgrade failed at version checking.
[00014937]========== 2015.11.05 16:58:28. boot(15) ============
[00015013]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00015089]Packet upgrade start...
[00015168]Packet checking...
[00015242]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015312]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015383]Done.
[00015455]Version checking[1]...
[00015655][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00015737][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015822][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015967][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016107][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016217][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016341][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016441][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029027][15 00][00] device not detected.
[00029136][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029298][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029401][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029474][01 00][00] v1.23.3419 -> v1.23.3419
[00029551][01 01][00] v1.23.3419 -> v1.23.3419
[00042123][08 00][00] device not detected.
[00042199]Done.
[00044271]Waiting for user confirm...
[00054342]Timeout, start upgrade automatically.
[00054499]Firmware upgrading[1]...
[00054760][03 06] Firmware upgrade start...
[00391392][03 06] Firmware upgrade finished successfully.
[00391492][04 00] Firmware upgrade start...
[00450329][04 00] Firmware upgrade finished successfully.
[00450408]Done.
[00450488]Version checking[2]...
[00450587][03 05][00] v34.2.0.9 -> v34.2.0.9
[00450690][03 06][05] v2.3.0.13 -> v2.3.0.13
[00450772][04 00][05] v1.41.0.0 -> v1.41.0.0
[00450865][09 00][00] v1.7.0.3 -> v1.7.0.3
[00451030][11 00][00] v1.7.0.0 -> v1.7.0.0
[00451159][12 00][00] v1.10.0.0 -> v1.10.0.0
[00451286][12 01][00] v1.10.0.0 -> v1.10.0.0
[00451419][12 02][00] v1.10.0.0 -> v1.10.0.0
[00451563][12 03][00] v1.10.0.0 -> v1.10.0.0
[00464136][15 00][00] device not detected.
[00464339][17 00][00] v1.1.1.7 -> v1.1.1.7
[00464499][17 01][00] v1.0.2.7 -> v1.0.2.7
[00464599][19 00][00] v1.0.8.96 -> v1.0.8.96
[00464672][01 00][00] v1.23.3419 -> v1.23.3419
[00464748][01 01][00] v1.23.3419 -> v1.23.3419
[00477318][08 00][00] device not detected.
[00477390]Packet upgrade failed at version checking.
[00014758]========== remo-con disconnect. boot(15) ============
[00014838]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00014912]Packet upgrade start...
[00015068]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015222]Done.
[00015295]Version checking[1]...
[00027873][03 05][00] device not detected.
[00040452][03 06][00] device not detected.
[00040542][04 00][00] v1.41.0.0 -> v1.41.0.0
[00040639][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00053223][11 00][00] device not detected.
[00078377][12 01][00] device not detected.
[00090951][12 02][00] device not detected.
[00103526][12 03][00] device not detected.
[00116105][15 00][00] device not detected.
[00128681][17 00][00] device not detected.
[00141265][17 01][00] device not detected.
[00153840][19 00][00] device not detected.
[00153912][01 00][00] v1.23.3419 -> v1.23.3419
[00153991][01 01][00] v1.23.3419 -> v1.23.3419
[00166564][08 00][00] device not detected.
[00166643]Done.
[00168719]Waiting for user confirm...
[00178802]Timeout, start upgrade automatically.
[00178950]Firmware upgrading[1]...
[00179050][09 00] Firmware upgrade start...
[00229478][09 00] Firmware upgrade finished successfully.
[00229557]Done.
[00229631]Version checking[2]...
[00229746][03 05][00] v34.2.0.9 -> v34.2.0.9
[00229871][03 06][00] v2.3.0.13 -> v2.3.0.13
[00229952][04 00][00] v1.41.0.0 -> v1.41.0.0
[00230056][09 00][05] v1.7.0.3 -> v1.7.0.3
[00230206][11 00][00] v1.7.0.0 -> v1.7.0.0
[00230355][12 00][00] v1.10.0.0 -> v1.10.0.0
[00230600][12 01][00] v1.10.0.0 -> v1.10.0.0
[00230717][12 02][00] v1.10.0.0 -> v1.10.0.0
[00230838][12 03][00] v1.10.0.0 -> v1.10.0.0
[00243419][15 00][00] device not detected.
[00243536][17 00][00] v1.1.1.7 -> v1.1.1.7
[00243701][17 01][00] v1.0.2.7 -> v1.0.2.7
[00243797][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243874][01 00][00] v1.23.3419 -> v1.23.3419
[00243950][01 01][00] v1.23.3419 -> v1.23.3419
[00256525][08 00][00] device not detected.
[00256603]Packet upgrade failed at version checking.
2015-11-5
Xterminator.971
justin.bregar Posted at 2015-10-2 19:40
The cable was loose. It was in there, so it looked ok but when I tapped it it fell loose meaning it  ...
Hello  Justin.bregar you tell me which cable ? picture if posible
2015-11-7
karel
Flight distance : 1333740 ft
Brazil
Congrats to mr sploodge for help ^^
2015-11-8
karel
Brazil
Xterminator. The cable that comes from vps unit to the gimbal. The grey small.
2015-11-8
cwongck
Flight distance : 730656 ft
Malaysia
DJI-Tim Posted at 2015-9-25 17:57
Hi DJI-Tim,I have updated my P3P with IOS V2.40, aircraft V1.4.10, RC 1.4.30. Now when I started up , there is no Video signal from the Ipad mini4 except fot DJI logo. Any suggestions how to fix the problem.
2015-11-12
m4schler
DJI-Tim Posted at 2015-9-25 03:57
Oh. don't do that.  It's akin to sending your email into a black hole.  Call the DJI support number.  You'll get a scripted response from a unknowledgeable resource, but at least you'll be able to get an RMA number to send it in to them.
2015-11-12
cwongck
Malaysia
m4schler@gmail. Posted at 2015-11-13 04:18
Oh. don't do that.  It's akin to sending your email into a black hole.  Call the DJI support numbe ...
Sorry if I am not doing the right thing here. I will send my P3P to the authorized dealer where I bought my P3P.Thank you for you reply.
2015-11-13
m4schler
cwongck Posted at 2015-11-13 02:56
Sorry if I am not doing the right thing here. I will send my P3P to the authorized dealer where I  ...
That's probably best.  You'll get a faster response that way.
2015-11-14
