Using SDK to override gimbal rotation limit of 540°
223 7 10-11 21:47
Peter Malte
Hi, I would like to know if it is possible to avoid the 540° rotation limit using SDK.
Is it rather a hardware thing though?  I have linked a video below where this team had infinite rotation (it is in one direction if you slow it down), and I heard they use arduino too if that is even possible.
I'd just like to know if anyone has done it before because I haven't seen it discussed or if anyone knows how to do this.
Link: https://youtube.com/clip/Ugkx24IeEnKUOuBin7O3attzSPdJU1acjsm5?si=DgY8LueUxlDQVZXE
10-11 21:47
BGA
There are a couple of ways you could do it. For example:
1 - Use chassis.drive_wheels() to control the wheels directly.
2 - Using chassis.drive_speed().
10-15 07:36
Peter Malte
BGA Posted at 10-15 07:36
Would that prevent the head gimbal from locking and moving with the chassis? I just want to prevent that and make it seem like it's on a bearing. I mean effectively ignoring the turning range of the gimbal
10-15 08:30
BGA
Peter Malte Posted at 10-15 08:30
Ah, you want to do that while keeping the gimbal pointed in the same direction? That is not possible hardware-wise on a stock EP. There is an actual physical limit to it which whoever did that in the video that you pointed might have removed.
10-15 11:20
Peter Malte
BGA Posted at 10-15 11:20
So do you mean that it is possible to remove it? Just altering the insides? Do you have any idea how?
10-15 15:29
BGA
Peter Malte Posted at 10-15 15:29
It must be because someone clearly did it. I have no idea what that would entail.
10-16 04:30
BGA
BGA Posted at 10-16 04:30
Even with the robot off, you can manually move the gimbal around and you will see at some point it just bumps into something and you can not move it further. I would check what is causing that and consider how it could be removed and what would be the possible side-effects. Be careful as you might actually break the robot.
10-16 04:33
Peter Malte
BGA Posted at 10-16 04:33
Alright thanks man, maybe I'll check it out
10-16 04:37
