Machoman
Flight distance : 1036959 ft
Austria
The self tightening will NOT fit your QR mounting. There are other ones you can try but you have to find mounting plates also for them. Be aware there are two different motor types used for the inspire which need different mounting plates. You first need to know which motor type you have.
Almost any prop at 13 AND 14 inch can be used basically there are 3 groups.
1. the original DJI plastic props - everyone knows them
2. Low quality Carbon fiber props like Tarot which are not 100% balanced but only USD 25,- (4) if you order directly - double if you order at resellers
3. High quality Carbon Fiber like T-Motor which sell around USD 140,- (4)
Until now I didnt find real comparison tests.
Best thing is to carefully test and findout yourself, I cannot tell you which are better or not. Rumors say Tarot or T-Motor 14 inch lead to longer flight time, smoother flight, less noise BUT also less agility but I didnt test it myself now.
(With the self tightening ones I would be more careful if the locks fit and they cannot spin off.) Anyway if a shop explicitely sells it as for Inspire 1 you are on the safe side if anything happens you can sue them. DJI will gladly confirm you that DJI did not approve them
