Firmware Fail to Update
375 3 2024-10-13
Khairsood
Malaysia
I am using a Mini 3, which has recently been displaying a firmware update failure with error code 0x1121056000FC. I am unsure if this issue is related to the new iOS 18 or to another cause.
2024-10-13
DJI Tony
Hi there. Please be aware of these points:
• Before updating, ensure that the battery level of the device (remote controller or aircraft) is above 50%.
• While updating, do not power off the aircraft or disconnect the USB cable. Otherwise, the update may fail.
• While updating, the device may automatically reboot several times. When rebooting, it is normal for the remote controller to disconnect from the aircraft automatically. Do nothing before the update is completed to avoid affecting the normal updating process.
We recommend using the app for updating (* Ensure that the mobile device has a stable network connection during the update process.) . If the update fails, please refer to the method below and try again:
1. Power off and reboot the remote controller and aircraft. Try updating again (Try this a few more times if necessary.).
2. If possible, use another mobile device and try again. For example, switch an iOS device to an Android device.
3. If the update using the app still fails, we recommend using DJI Assistant 2 for updating if you have a computer on hand.
*Path for checking firmware updates within the app:
DJI Fly: Profile on the homepage > Settings > Firmware Update > Check for Firmware Updates.
4. If the updating still fails after the above methods have been used, please tell us for further analyze.
2024-10-13
djiuser_2eIq1fsBWmv2
Brazil
DJI Tony Posted at 10-13 03:45
Ryan Silveira Puzzi
‪+55 11 93385‑8880‬
ryansilveirapuzzi@gmail.com
Meu drone não quer atualizar tentei de todas as formas e está dando falha e por falta de atualização ele não faz vou como posso resolver esse problema por favor trabalho com isso
2024-10-24
DJI Wanda
djiuser_2eIq1fsBWmv2 Posted at 10-24 18:00
Ryan Silveira Puzzi
‪+55 11 93385‑8880‬
Hi, there
We apologize for the inconvenience that you are encountering.
Could you please tell us which the model of the drone are you referring to?
Is there any error message show up?
Please provide more detailed information, we will check it out for you.
2024-10-24
