Propeller motor malfunction
1458 6 2014-12-14
azwan.baharudin
Malaysia
Hi all, im having trouble with my DJI Vision 2 +, one of my motor does not spin smoothly. Motor seem to struter when i start, but back to normal when i give a full throtle and in idle the motor will stop. Anybody else have similar issue?. Im really lost of idea how to correct it, i never fly this drone yet
2014-12-14
Dboy
China
Never met that before... have all the screw are tightened?
Did you install a prop guard?
Through your feeling, does this motor move/accelerate slower than others?
2014-12-14
matthew
I am having a similar problem with the same phantom that just started today.  I have 3 batteries total, 2 fully charged batteries that have been stored for about a week, when I start the motors, one is intermittent.  I didn't take off because I was nervous it would crash so I don't know if it fixes once flying.   When I tried my third battery that had about 50% charge, the motor ran fine.....leads me to believe I might have 2 faulty batteries but how after only 5 charges tops?
2014-12-17
Gerry1124
matthew@vacatio Posted at 2014-12-18 07:30
I am having a similar problem with the same phantom that just started today.  I have 3 batteries tot ...
A faulty battery would not affect just 1 motor, it would affect ALL FOUR motors.
2014-12-17
matthew
Gerry1124 Posted at 2014-12-18 07:46
thanks for the reply, its just odd how 1 battery works fine, then the intermittent motor starts if I use the other 2
2014-12-17
Gerry1124
matthew@vacatio Posted at 2014-12-18 07:51
thanks for the reply, its just odd how 1 battery works fine, then the intermittent motor starts if ...
Does it usually start working after you put in the third battery? It could be your motor has warmed up enough after the other 2 batteries have been tried.  Try the other 2 batteries first, then the one you think is defective  last.   See if the motor works then.
2014-12-17
humboldt710
Sounds like a faulty speed controller on the suspected motor.
My Hanger
Phantom 2 w/H3-3D gimbal & GoPro Hero3+, 600mw 5.8vtx w/VAS BB Ultra, Large Skids
Phantom 2 w/600tvl, 400mw 1.3 vtx w/VAS BB Ultra, 2.4 Notch Filter, V2 ESC's, MultiStar 2212 Motors, FrSky X6R, Custom Skids
Lumenier QAV250 Carbon on 4S, Cobra 2204/1960 Motors, KISS 18a ESC's, Angled/Extended Mounts, CC3D, FrSky D4R-II, Mobius (almost done!)
Hubsan X4 Stock mini racer, Hubsan X4107D Non FPV(now) racer project, Taranis X9D w/external Antenna & 2200mah lipo, Dominator V2 goggles
2014-12-18
