ag0n
Flight distance : 700846 ft
I hit the Return to home button a few times and luckily the feek came back. I was wondering if the drone goes out of range or possibly hits radio interference, will hitting the return to home feature still work.
Ray is correct. The FPV signal has nothing to do with control, just the video feed back to you. The one thing that bothers me is your wording that you "hit the return to home button a few times". Are you aware that this is a push and hold until it beeps button? If you just tap it, it won't RTH. Push and hold, it beeps, the device will say something like 'return to home activated', the LED around the button will light up, the P3 will turn toward you, it will rise to the RTH altitude unless you are higher than that already, and return home and land. |
