Implement RTH with Neo controlled by phone
574 10 10-16 08:40
SKSVip
Dear DJI,
i'd like to have RTH while i control the DJI Neo with mobile phone.
Three times i lost the control of the drone and was very difficult to reconnect
If there is RTH it could be a nice to have for me.... RTH with button and if connection is lost...
I already know that RTH is available if DJI Neo is controlled by DJI RC-Nx
Thanks and best regards
AC
10-16 08:40
MiniManiac
Flight distance : 1454524 ft
Its max distance is 50m with a phone, its only meant to be used to fly within line of sight, if you want to go further then use a controller.
10-16 09:11
SKSVip
MiniManiac Posted at 10-16 09:11
The RTH can solve a problem like this:
If I fly over sea at 10 meters to make video to my boat and i loose the connection the drone stay over the sea and land into the sea when the battery is low...
Only by chance did he land on another boat and not in the sea...
I don't know why the connection didn't work, but after recharge the connection is normal again.
For me RTH can be very usefull (better if i can choose on or off before take off).
For me can be also usefull have a button to RTH if i see problems (for newbie like me)....
10-16 13:26
MrDinB
Flight distance : 67923 ft
DJ DJ you must fix! Before our drone does tricks tricks tricks!
10-16 14:54
DJI Diana
Flight distance : 2408 ft
Hi there, SKSVip.
Thank you for bringing this to our attention. We assure you that we will convey this to the relevant team for consideration and action. We appreciate your patience and kind understanding.
10-17 20:23
umpa
Flight distance : 19560 ft
DJI Diana Posted at 10-17 20:23
Hi there, SKSVip.
Would you give DJI's perspective on why this was not implemented, is it legislation or simply DJI thought it was unnecessary ? or a hardware limitation.
10-19 00:24
umpa
In the UK you have to fly LOS anyway, so that argument has no weight.
RTH should be implemented for use on the phone controller also.  You can lose a drone at any distance.
I don't know why it has not been, and I have not yet had answers to my questions aimed at DJI.
10-28 06:44
Hill Peaceman
United Arab Emirates
SKSVip Posted at 10-16 13:26
Hi,
It happen's to me also when flying over the sea with a Jetski in Dubai.
I launch a Dronie (4m) and instead of going back he continue to elevate about 30 m and stay stuck there during about 10mn.
I needed to wait until low battery has forced it to descend and I was able to grab it with my Jetski.
Any explanation.
11-9 07:15
Andycap
Flight distance : 646365 ft
I would also like this to be implemented.  There are lots of scenarios that this could save the Neo from loss.
11-12 06:05
djiuser_uRoNuXNx1qEZ
Turkey
Everyone says the same thing. But why don't people consider emergency situations? For example, let's say it is within your line of sight and in Wi-Fi range. If a sudden and unexpected gust of wind blows it a hundred meters away, you won't be able to retrieve it unless you go toward it. So, if it's in difficult terrain, you may not be able to get close to it.
11-20 04:34
DJI Diana
Andycap Posted at 11-12 06:05
Hi there,
thank you for reaching out.
We will consider this feedback as a request and forward it to the relevant team for their attention. We appreciate your support and kind understanding.
11-20 23:05
