Like Neo to have these features
481 8 2024-10-16
threeboxerdogs
Philippines
Hi,  Let me know if NEO can already does the following, if not, then nice features for the future upgrade:
  • We can connect NEO directly to PC  without turning it on and access the videos, can we do this with iPhone? QuckTransfer requires NEO on and DJI fly app connection, that takes time and drains the battery
  • In the 'Follow' and 'Directional Track', it has these distance(near, far) and height (low, flat, high), we need to connect to NEO to change, can we use hand gestures? say left hand adjusts the distance and right hand adjust the height?
with these two, it will save battery and less complicated in using NEO which is the strong selling point I bought NEO, it functions just like a flying camera
Thanks,
Three
2024-10-16
DJI Gamora
Hi there,
Unfortunately, DJI Neo does not support Gesture Control and for QuickTransfer with DJI Neo you need to turn on the device.
Thank You for your feedback, we will forward this information to the relevant team for evaluation.
If you have any other questions, kindly let us know. Thank You!
2024-10-16
djiuser_5GX1SK6oJv61
I have a small wish list for further development:
App:
1.Dark mode
2. The possibility to change camera parameters: sharpness, saturation
Useful accessories:
1. A solo USB-C charger for one battery, only with a plug (limits space in your luggage)
2. smartphone holder with control sticks allows you to hold the smartphone horizontally/enlarged the screen and let the aircraft to be controlled better.
Guess some users would like that. Possibly Neo 2 ;)
2024-10-17
But first of all: the ability to switch to ATTI mode manually.
This prevents uncontrolled behavior during the automatic modeswitch when flying only indoor.
Mercy
2024-10-17
...and please stiffen the two jaws that are supposed to enclose and protect the gimbal.
In the event of an impact, the camera is pushed out of the holder.
2024-10-17
threeboxerdogs
Philippines
for the #1, getting video from NEO using a cable in iPhone, somebody posted a video:
https://youtu.be/wZ-uR50Es54?t=489
That's cool, but when I tried it, my Files App in iPhone does not have InternalSto like what he shows in the video, could anybody confirm this? Thanks
2024-10-18
What kind of iPhone is it? It works perfectly on devices with a USB C connector (from iPhone 15). Not with lightning plugs
2024-10-19
threeboxerdogs
Philippines
djiuser_5GX1SK6oJv61 Posted at 10-19 00:33
you are right, what I have is the lightning plugs, iphone 13 pro max.
2024-10-19
OldGuy2024
Flight distance : 632428 ft
djiuser_5GX1SK6oJv61 Posted at 10-17 06:39
Definitely a feature needed for indoors flying.
Purchased the Neo primarily as a manual mode trainer and indoors flier.  Don't dare fly it indoors unless the lighting is relatively even and bright.  Bit scared to even fly the Neo under the shadow of the coffee and dining room table.
2024-10-19
