Skywolf007
Flight distance : 2758875 ft
Slovakia
I never had this exact problem you described, but had others. When you save a waypoint and you load it for a flight, DO NOT chose the flight mode "Consistent with the record" (I guess its called that)
Always chose consistent with the ROUTE - the record option will reproduce every slight movement you make during flight, and I guess its bugged a bit. My guess that it will count previous wind speed and correction into your actual flights.
However if you use the Route option - which is the best for photogrammetry, it will fly from point A to B, and will ignore all previous staff recorded.
I use route option for photogrammetry and it works really well, I work with pix4d 2.0 so far, but will check some other software.
BTW What massive area you are flying that you need 10 flights!! You can easily cover 3-5km/ flight in waypoint mode, so I guess you were mapping a whole village |
