AR Return-to-Home Route
1173 6 2024-10-21
Funn 1
Flight distance : 230302 ft
Just curious, I seen some videos where the  AR Return-to-Home Route (green line) works on the Neo. But when I'm using goggles 3 I don't have that feature. Is anybody else seeing this?
2024-10-21
DJI Gamora
Hi there,
Thank you for reaching out. When using DJI Neo with a remote control device or goggles, the signal lost action can be modified as Hover, Land, or RTH. There is only landing function due to critically low battery and no Smart RTH option if DJI Neo is controlled via Wi-Fi or without a controller. If you are facing diffrent issue then the mentioned above please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-10-23
Zab Devin 2
Flight distance : 2642700 ft
Yes, I noticed it yesterday. I thought that maybe it only works with the controller. I’ll have to do more testing.
2024-11-2
Zab Devin 2
DJI Gamora Posted at 10-23 03:14
Hi there,
You didn’t answer the question. Does smart return to home work when using the Goggles 3 and FPVRC2 or not?
2024-11-2
umpa
Flight distance : 19560 ft
Zab Devin 2 Posted at 11-2 10:33
does the FPVRC2 even work with neo ?
2024-11-3
DJI Gamora
Hi Zab, Unfortunately, DJI Neo does not support for DJI FPV Remote Controller 2. For compatibility you can refer this link DJI Goggles Series and Motion Controllers Compatibility for Camera Drones .
Please do take note as mentioned on thread 2# There is no smart RTH option if DJI Neo is controlled via Wi-Fi or without a controller. If you would like to use DJI Neo with DJI Goggles 3, it can use it only with DJI FPV Remote Controller 3 or DJI RC Motion 3.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-11-5
DJI Gamora
umpa Posted at 11-3 02:57
Hi umpa,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Unfortunately, No, DJI Neo does not support for DJI FPV Remote Controller 2. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-11-5
