F055y
Flight distance : 61885322 ft
Request #1:
DJI Terra, when processing the L2 Lidar sensor data, there are times that it produces noisey data in localized areas. It can be delt with, but the software really needs a noise reduction filter. General premise of the filter is to search for neighouring points within a distance, if little to no points are found, those said point is removed. This should get rid of about 90% of bad data.
The fact that these nosiy areas exist, messes with the ground classification. So the noise reduction filter needs to be processed BEFORE any ground classification takes place!
Before anyone asks. YES! the sensor is calibrated and the IMU calibration is enabled for each flight.
Request #2:
Terra needs option to process a orthomosiac image when using the L2 Sensor and processing a colourized LiDAR flight. It has all the necessary tools and information to do it, but its not an option. If you got a DEM, and Images, its pretty easy to create an Orthomosaic
