Going low with avata 2 in N or S mode.
261 14 10-23 22:16
BadBert
Flight distance : 187910 ft
Hello,
is it possible to fly lower than 30cm with the avata 2 in N or S mode?
i know that if you fly and go over something "small" that is closer to the drone it has no issue with it, but when you want to fly over something a bit bigger/longer it automatically goes up to 30cm after a short while.
i was going thru some kind of tunnel situation, and the drone went up by itself half way in......
tested this going low to the ground but the drone does not want to go lower than 30cm.....
10-23 22:16
yogi053
Flight distance : 26104915 ft
I flew mine into the ground in sport mode because I was flying low. Luckily it was a grassed area and no damage was done except for grass stains. It was a slow rise in the ground so I don't think the drone had time to recognise this.
10-23 23:16
BadBert
yeah, that's what i experienced also, but i want to be able to fly lower than 30cm....
10-23 23:22
yogi053
BadBert Posted at 10-23 23:22
30cm=1 foot. How low do you want to go? (I'm a poet and didnae know it). LOL
10-23 23:28
BadBert
i would like to be able to fly as low as 10 cm, but 15 is also good.
10-23 23:30
yogi053
BadBert Posted at 10-23 23:30
Well, good luck Bert. Hope you have plenty of Care refresh when you are trying that.
10-23 23:36
GTHero
Flight distance : 1910125 ft
How far does it go before rising up, and have you tested it at different speeds?
10-23 23:45
BadBert
yogi053 Posted at 10-23 23:36
I am not doing that at high speeds.... it is for shooting video of machines we make at work, i want to be able fo fly lower to the conveyor belts that run thru them.
10-23 23:48
BadBert
GTHero Posted at 10-23 23:45
is seems like around 5 meters, after that it goes up to 30cm.
i tried some different speeds but not that fast as i was flying indoors.
10-23 23:48
OldGuy2024
Flight distance : 632428 ft
Yes, but only above a certain minimum speed.  Zipping along our township gravel road and up my driveway in the "red".  15-16m/sec feels like warp 1.  Focused on flying.  Took a look at the recording. Below 0.3m.   A reason not to hover or fly too slow when just above the tree canopy.  I keep it in the "yellow" or higher when the downward sensor detects the the tree tops as the "ground".
The few indoors session are another issue.  Flying too slow at times. Self landing kicks in when ducking under tables.
10-24 11:40
BadBert
that's the issue.... i want to be able to fly slower and lower.....
we want to make nice shots going thru machines we make, but it's always over some kind of conveyor.
10-24 23:19
fichek
Flight distance : 1289590 ft
Croatia
Nope, you'll have to use M mode to go lower. And you'll have to fight the ground vortex, which is probably why this limit exists in the first place in N/S modes.
10-24 23:58
BadBert
i understand i can do that in M mode, but i hoped there was a way in N/S mode....
i am not confident enough flying thru tight spaces in M mode.... i really don't have much room inside our machines... that's why 30cm i to high, it will hit parts of the machine going that "high"
10-25 00:00
eried
Flight distance : 1186007 ft
Denmark
BadBert Posted at 10-25 00:00
maybe you could stick a camera with a little stick that goes very low?
10-25 04:07
yogi053
eried Posted at 10-25 04:07
Now that's an idea. A GO PRO underneath instead of on top. Good luck.
10-25 23:01
