DJI Natalia
yohnny Posted at 10-30 12:37
Hopefully you can see that the sd card is inserted and that it reads no SD card, even through the out of focus shot.
Thank you for providing the necessary information. There are a few possible causes to this issue, which are:
1. The microSD card is not compatible with the aircraft.
2. The microSD card is damaged.
3. The microSD card cannot be recognized as the aircraft port is damaged.
To resolve this issue, we highly recommend using the microSD card, please refer to List of Recommended Storage Cards for Drones. For the Mini 4 Pro, you may refer the following.
• SanDisk Extreme PRO 32GB V30 U3 A1 microSDHC
• Lexar 1066x 64GB V30 U3 A2 microSDXC
• Lexar 1066x 128GB V30 U3 A2 microSDXC
• Lexar 1066x 256GB V30 U3 A2 microSDXC
• Lexar 1066x 512GB V30 U3 A2 microSDXC
• Kingston Canvas GO! Plus 64GB V30 U3 A2 microSDXC
• Kingston Canvas GO! Plus 128GB V30 U3 A2 microSDXC
• Kingston Canvas React Plus 64GB V90 U3 A1 microSDXC
• Kingston Canvas React Plus 128GB V90 U3 A1 microSDXC
• Kingston Canvas React Plus 256GB V90 U3 A1 microSDXC
• Samsung EVO Plus 512GB V30 U3 A2 microSDXC
Besides that, please try to install the microSD card to another device and see if the microSD card can be read normally. If not, use another microSD card. If yes, please take out the microSD card, back up the required information, format the microSD card, reset the camera parameters of the aircraft, and then insert it into the aircraft again.
Lastly, you can try to format the MicroSD Card via DJI Fly. Formatting the MicroSD Card via DJI Fly. In the camera view, tap the System Settings icon at the upper right corner of the screen, enter “Camera” and tap “Format”. We hope this helps. Thank you! |
