Gimble clamps
618 8 2015-9-26
jayhkr
So I'm not sure how I did it, must had been tired or not paying attention, but I somehow installed the plastic clamps on all 4 sides of the gimble. How do I remove 2 of them?
2015-9-26
rayrokni
Flight distance : 8139875 ft
you need to snip the end and it then will come off
2015-9-26
JtrJr-UAV Pilot
Flight distance : 4341 ft
Jay,
I've been able to re-use them. Had to take my camera apart at one point. I took a small screwdriver about the size of an eyeglass driver. There are 4 small tabs on the lower plastic washer. Take the driver and lightly pry the tabs away from the plastic pin. Once you get them far enough away from the pin you can pull the lower washer off. As soon as you pull the washer off, push those tabs down towards the center, the way they were before you pried them outward. If you don't want them as spares, do as ray suggested and just snip them off!
Jerry
2015-9-26
EL SID
Is there any issue keeping them on?
I put the other two on as well thinking they should be on.
2015-9-26
JtrJr-UAV Pilot
EL SID Posted at 2015-9-26 21:16
EL,
Probably not. I'd probably take them off. They're just on there to keep the camera from separating. The little white buffers are intended to allow the camera to "float", keeping down vibration and allowing for free movement. In this case, I think less is better. That's my two cents.
Jerry
2015-9-26
noticon75
Flight distance : 14698 ft
I don't know if I would reuse them as cheap as they are I'd just keep several as spare instead of chancing on a couple hundred dollar camera.
2015-9-26
jayhkr
JtrJr-UAV Pilot Posted at 2015-9-26 21:25
EL,
Probably not. I'd probably take them off. They're just on there to keep the camera from separ ...
The reason why I was asking was because one of my video's last week at a "shaking" in it that I've never noticed before.  I'm "assuming" it was caused by this as I thought I read somewhere it could cause shaking if we had all 4 of the "clamps" on it.  Thanks all for the replies.  I'll just snip them and order some more.
2015-9-26
-=RaM=-
Just push the washer further down the main pin so it pushes the tabs out then push the washer off of the pin,,the tabs on the washer will reset themselves after a minute or so.
2015-9-27
Rocket_Aus
Flight distance : 1526929 ft
jayhkr Posted at 2015-9-27 14:04
The reason why I was asking was because one of my video's last week at a "shaking" in it that I've ...
You can pull them off using your fingernails they can be reused.
2015-9-27
