Flyaway after smooth flight
456 14 10-26 08:47
sbright33
Had my first Neo Fly Away everything was going great smooth video above the houses and wires. Then lost GPS which caused a tumble still high. "Unable to return to home". High winds, even though they were not. Flipped a few times in an Arc at 20m out of control. Then went down. Of course I have the flight log. Thoughts?
Steve
10-26 08:47
Pleomax
Flight distance : 835725 ft
Hi, better to post flightlog from the flight.
Easier to diagnose a possible problem from the log.
You will get information as to where to find your flightlog in the link below.
https://www.phantomhelp.com/LogViewer/Upload/
Then share the link to the uploaded log here on the Forum.
10-26 10:10
sbright33
Pleomax Posted at 10-26 10:10
Thanks for your link above. Back in the day we used iTunes to find the log files. Now I can view the flight in the Fly App. How can I get this file without iTunes?
10-26 10:38
sterreeler
Flight distance : 3642 ft
Philippines
sbright33 Posted at 10-26 10:38
you can use your phone
10-26 11:39
sbright33
sterreeler Posted at 10-26 11:39
I can view the replay on iPad. How can I get the file with my "phone"?
10-26 13:55
DowntownRDB
Flight distance : ****
sbright33 Posted at 10-26 13:55
Steps to retrieve the TXT flight logs from an Apple device with iTunes here:
https://www.phantomhelp.com/tips ... logs-from-itunes.29
Steps to retrieve the TXT flight logs from an Apple device with Finder - just scroll down from above link.
Hope this helps.
10-26 16:11
Narg
The NEO is not a highly precise drone.  YMMV in other words.  I have these often.  The shadow of a tree can make it dart off course.  (it uses it's camera for positioning, which is good in great light, but not always.)  It doesn't keep contact with GPS very well from what I see.  DJI has some work to do IMHO.
10-26 19:54
fallenangel3k
(this is the mentioned instruction from the mentioned site above.)
For mobile devices, connect your mobile device to a computer via a USB cable and go to:
** DJI Fly
a) DJI\dji.go.v5\FlightRecord (for older versions of DJI Fly)
b) DJI\dji.go.v5\files\FlightRecord (for iOS devices)
c) Android\data\dji.go.v5\files\FlightRecord (for Android devices)
EDIT: Turns out the (android\data\)dji.go.v5\ folder is very valuable and holds a ton of interesting files. did not know until know - i was looking on drone and rc insteads. thanks)
10-27 22:22
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We apologize for the inconvenience. If you find or retrieve your drone, it is recommended that you submit an Online Repair Request and send your aircraft back for diagnosis to avoid unnecessary danger in the next flight. If your aircraft cannot be found back, then submit a flyaway case.
Feel free to contact us if you have any questions.
10-28 03:26
sbright33
I can see these files without iTunes?
10-28 05:46
sbright33
DJI Diana Posted at 10-28 03:26
Hi there,
Flyaway case submitted Thank You!
10-29 11:25
relaxosmo
Flight distance : 776585 ft
Hungary
steve: which controller?
10-29 11:42
sbright33
relaxosmo Posted at 10-29 11:42
RC-N2 along with iPad
10-29 11:47
DJI Diana
sbright33 Posted at 10-29 11:25
Hi there,
We appreciate the update provided and are glad the issue is being handled. Please keep us updated on the progress.
10-30 19:45
sbright33
See this thread for results:
https://forum.dji.com/forum.php?mod=viewthread&tid=322963
10-31 13:36
