The Ollie
Flight distance : 140187 ft
DJI Gamora Posted at 10-31 22:24
Hi The Ollie,
Thank you for your patience. We have check with the relevant team on this matter. The Integra goggles and Mini 4 Pro still use the older O3+ transmission standard, rather than the newer O4. This means the Mini 4 Pro is compatible with older O3 and O3+ devices, and the Motion 2 also uses O3+ to connect to the Mini 4 Pro. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
Thank you for your answer.
But this means that the Mini 4 pro has to be also compatible with the O4 transmission standard to connect with the RC-2. Depending on whether the integra or the RC-2 is connected to the Mini4 pro, the mini 4 pro switches from O3/O3+ to O4.
And the RC-2 can only run O4, so that downward compatibility is not possible?
But in this case I ask myself, why it is possible to connect the Mini 3 pro the integra and the RC-2 together with this workaround? |
