OldGuy2024
Flight distance : 632428 ft
DJI Natalia Posted at 11-2 21:42
Hi there, thank you for reaching out and sharing your experience using MasterAirscrew propellers. Just a friendly reminder that DJI does not recommend your 3rd party accessories on your DJI product or modify your DJI product. These 3rd party accessories might affect the DJI drone when in use and there is a possibility that these 3rd party accessories will be able to work. However, since it's not yet optimized and tested by DJI we cannot guarantee the stability of the said 3rd party accessory if it will work all the time with no issues and might damage the said DJI product and can void the warranty of your DJI Drone as well. Thank you.
I hope this helps with your concern. Thank you for your support and have a nice day ahead.
Yes, I've seen this response before in other threads.
Only one concern if the MasterAirscrew(MAS) Neo propellers end up being 4 blade design like their Avata2 version. Additional torque load on the motors from the extra blade and mass. That's assuming identical pitch and surface area per blade.
On paper if identical to the stock Neo propeller but with one additional blade there might be an increase in max speed in manual mode at a given motor RPM. If tip turbulence is identical the additional blade tip turb. may result in minimal improvement. People have noted extra responsiveness in the Avata2 MAS. Seems bit counter to what should happen with the increased mass of the 4th blade. Assuming the MAS are heavier. Flight times might improve if the MAS deliver more thrust at a given RPM. Probably real minimal if any based on the Avata2 MAS v. stock. Same for sound volume.
Probably will stick with the Neo propellers unless there is significant improvement with flight times with the MAS. Did order the Avata2 MAS when they released the orange color. Just as an aid for spotting a downed Avata2. The whitish Neo is much easier to spot. That is, until the snow covers the ground. Normally apply a conformal coating (CorrosionX) for winter into spring flying. Not really something you can do with the DJI UASs. |
