Ch hack problem ...
1507 12 2015-9-28
BASS 666
guys i tried the ch hack tonight and it didnt work for me ... i followed the instructions to the letter to no avail .... i unrared it and put it in the right place on my android device but i still have the standard channels .... i tried custom and auto to no avail .... what gives ????
2015-9-28
Rocket_Aus
Flight distance : 1526929 ft
You might have to change the region on your device have heard that about the uk seem to be locked in anyway give it a try.
2015-9-28
BASS 666
Rocket_Aus Posted at 2015-9-29 00:13
You might have to change the region on your device have heard that about the uk seem to be locked in ...
yeah I done that ages ago and it gave me custom mode ....
2015-9-28
BASS 666
ANYONE ?????????????????????????????
2015-9-29
BASS 666
right when I open the file on my computer and look at properties its about 4kb in size then when I put it into my tablet its the same but when I turn the tab off and on again the file says no kbs in size ???? the file is empty when I turn the tab on again ....
2015-10-7
BASS 666
anyone help me with this guys ?
2015-10-8
BASS 666
SOLVED!!!!  I was putting the folder with the file into my tablet instead of just the file .... DOH !!!!
2015-10-9
Seabase195
Flight distance : 1710938 ft
BASS 666 Posted at 2015-10-10 02:42
SOLVED!!!!  I was putting the folder with the file into my tablet instead of just the file .... DOH  ...
My tablet will not accept the file. It shows the typical circle with a line drawn thru it like...."do not enter".
Can you give me a blow by blow on how you got this to work? I have a Samsung Tab A.
Thanks!
2015-10-14
BASS 666
Seabase195 Posted at 2015-10-14 20:01
My tablet will not accept the file. It shows the typical circle with a line drawn thru it like.... ...
i watched this guy then i found out what i was doing wrong after trying a few times ... hope this helps ... let me know ....
2015-10-14
scottgraser
Flight distance : 2446266 ft
Could someone please explain what benefit performing this would give me? I have the P3 Standard. Thanks!
2015-10-14
BASS 666
scottgraser Posted at 2015-10-14 23:10
Could someone please explain what benefit performing this would give me? I have the P3 Standard. Tha ...
it gives you more channels to choose from in custom mode .... some of the channels are illegal and some people care and some don't .... the channels from 20 to 30 are not as busy as the rest so you get good quality feed from them ....
2015-10-14
BASS 666
did you get it sorted ?
2015-10-16
Gary C
BASS 666 Posted at 2015-10-17 02:57
I did...it did not accept the hack because I already did it for my other P3....duh. Thank you though for asking.
2015-10-22
