DJI GO App no longer shows Location in Pilot Log
921 6 2015-9-30
fdnyfish
Flight distance : 7965640 ft
DJI GO App no longer shows location while viewing Flight Records....
In the past, when I looked at my Flight Records, the Location was always populated.
Now the location just says MAP LOADING.
Did I change something along the line? , Is anyone else seeing this?
Using an iPad Mini 2 with Verizon LTE
2015-9-30
fdnyfish
2015-9-30
benwill1
Same problem here. It's am iOS 9 issue. The icon doesn't move with you flight path either. DJI has released a new app, pending Apple approval. It should be fixed soon.
2015-10-1
benwill1
A fix is on the way. I assume you have an apple product?
2015-10-1
fdnyfish
benwill1@hotmai Posted at 2015-10-2 08:26
I have both, and both do the same
2015-10-3
fdnyfish
I just uninstalled the dingo app, and then downloaded it again.  Once I did a sync of flight records, all the locations are now there.  This was on iOS, I'll have to check android
2015-10-3
Phantom Paul
Philippines
My Android is having the same problem.
2015-10-4
