Phantom Paul
Philippines
In your DJI Go app > Library > select the video footage you want to cut (make sure you have downloaded the original file.
Once selected the video file, you can "Cut to Footage", i.e. you want to cut/use a certain portion of the clip only. Each cut is 6" long but you can adjust & extend the timing. Once done, click Save at the bottom (yellow highlight). After processing is done, it will added into your main library page.
In your main video library page, select those videos that you want to merge together or "Create Movie". Select your preferred Template. Check the preview. Once you are fully satisfied & happy, click Next. Once the Movie is completed, you can now upload & share it to the listed social media such as Tweeter, WhatsApp, etc.
It's fairly simple to use. Give it a try. Trial & error, you'll get it right in no time. |
