Glitch
It's a uniform loss of thrust so there is no drift or rotation.
If there was a chance for recovery after loosing altitude there was never enough altitude for the "fall" to allow time enough for thrust to return enough to either stave off impact or to even give an auditory cue that thrust had returned. (generally events have been closer to the ground, first time I wrote about in this thread)
first post in that thread has video.
Full throttle input on the controller only mildly slows the descent.
When connected to the Phantom Assistant, IMU and controller readings are normal and stable within respective ranges.
Granted I've not continually monitored the IMU for random failures for more than 5 min, nor do I understand the internal workings well enough to gauge likelihood of physical motion randomly initiating a fault.
After each impact, at least for a minimal stretch of time after repairing impact related damage as necessary, it's capable of flying without issue. After the first event, there was about a dozen flights, including an immediate relaunch to assess status, which was a normal flight for ~10min. The next event(#2) was during my systems checks immediately after launch. (systems obviously were not ok) After that event there was only one full flight which I did in my front yard without issue in an attempt to figure out possible cause.
Without any further indications of problems from that flight I had convinced myself that I must have missed a sudden rotor effect given the terrain during event #2 and that event #1 had been long enough ago that it was genuinely a random glitch. However almost two weeks ago during event #3 there was enough altitude to dismiss any possible terrain related causes, in addition to time of day precluding thermal activity, and calm winds up to 20k so winds aloft weren't remotely related.
Thank you for any help or insight! I've not found anyone else on the entire internet who has dealt with this issue.
