Hi there, thanks for reaching out.
Since you have an Osmo Action 5 Pro icon, are you referring to its pre-recording switch? If so, you can find the pre-rec toggle from this operation path: On the camera interface>>slide up at the bottom of the screen>>tap the icon in the upper-left corner and access the Pre-Rec Mode feature (positioned at the same menu level as the loop recording feature).
Here are the tips of the pre-recording features:
1. This mode is supported only when “Video” mode is enabled. Setting options of “Pre-Rec Duration”: 5/10/15/30/60s.
2. The Osmo Action 5 Pro has a pre-recording time setting range of 5/10/15/30 seconds, 1 minute, 2 minutes, and 5 minutes in version V01.02.03.10 and above(Please kindly check if you have updated to the version mentioned).
3. When Pre-Rec mode is enabled, you can only adjust the screen-off time and end prerecording on the camera touchscreen, while other interactions with the touchscreen are not allowed.
If you have any further questions in the future, please do not hesitate to let us know. We will be happy to help again.
