Agras T30 Plunger pump motor bearing
447 2 2024-11-26
Jaco_Atms
South Africa
Hi
I have a DJI Agras T30 plunger pump infront of me that has stopped working. The motor turns, but it is not giving nearly the correct flow and vibrating a lot!
I have opened up the pump, and as you can see on the inside, the motor shaft goes through two bearings, ons of them is completely broken. Can you please assist with the correct specifications of these bearings as I would like to replace them. On the bottom bearing I can see a code: "THAILAND NMB R-1980 KK". Specifically I would need the inside diameter, outside diameter and the width to ask for a replacement.
WhatsApp Image 2024-11-26 at 15.25.30_cd7947bf.jpg WhatsApp Image 2024-11-26 at 15.25.29_6dcddc38.jpg
2024-11-26
Jaco_Atms
South Africa
To be clear, i am looking for the specifications of the broken bearing in the first image
2024-11-26
LV_Forestry
Flight distance : 4726654 ft
Latvia
The one which is on the rotor is a 16.68*8*6
For the other one i suggest you simply measure it and you will get the reference of the right bearing.
2024-11-26
