david.p.mann
Flight distance : 18669501 ft
YES - you are correct. You should look for the channel with the lowest point on the graph because this is a signal interference graph. You want to wait for several minutes because the graphs shows average signal interference over time. I ALWAYS fly in Custom mode and use Channel 20 (lowest point on graph - lowest signal interference) about 90% of the time. I rarely have video signal loss. You also need to orient your antennae correctly (antennae parallel to one another, with wide flat sides of antennae facing the Phantom; thus, typically both antennae sticking straight up with Phantom in front of you). When flying the Phantom 3 at a great distance, it is important to keep your body oriented with the antennae aimed at the Phantom. At distances over 7000 feet, I typically lose RC Transmitter signal level BEFORE I have any problems with video transmission. Too bad there's not a manual setting and multiple channels available for the RC transmitter signal tranmission like there is for the HD video transmission signal. |
