DJI Go Doesn't Show Correct Aircraft Firmware
knupla2
Flight distance : 922 ft
I'm confused.  I'm updated on the P3P to the latest firmware 1.4.0010.
Here's the report:
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.08.05 08:30:17 =====================
Result: Abort.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2015.10.03 08:15:35 =====================
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.10.03 09:01:15 =====================
Result: Abort.
Result: Abort.
When I look at the About on the DJI app on my iPad Air 2, it shows 1.3.20+
Is that correct?  Is it possible that the iOS app version doesn't go beyond 1.3.20 - and it simply adds a +???
I'm certainly not trying to fly until I get an answer.  Too much invested to take the risk.
Thanks in advance.
2015-10-3
Mad_Angler1
Flight distance : 2741657 ft
Yes that's the controller version.  Check it again with everything turned on, the controller should benv1.320 and the craft v1.4
2015-10-3
Mad_Angler1
Your craft it upto date looking at the log.  Turn it all on and take a screen grab with it all connected. But you look good to go
2015-10-3
knupla2
That was the grab a few minutes ago.   I decided to shut it all down and turn on the P3P first, then the controller.  It did come up correctly identified.
I'm good.
Thanks.
2015-10-3
