DJI mini 4k drone data
684 5 2024-12-11
edwinmeriaux
Hello!
I am looking to buy DJI mini 4k. Aside from GPS data is there anyway to get IMU and camera gimble angle?
If this is not avaliable on the DJI mini 4k is there a DJI where we can get this?
Thank you!
2024-12-11
DJI Natalia
Hello, thank you for your interest in the DJI Mini 4K. The DJI Mini 4K does indeed have an IMU (Inertial Measurement Unit), which helps with flight stabilization and control.
Regarding the camera gimbal angle, could you please elaborate on what specific information or functionality you are referring to?
Understanding your needs better will help us provide more accurate information or suggest a suitable DJI model that meets your requirements.
2024-12-12
edwinmeriaux
DJI Natalia Posted at 12-12 04:06
Hello!
Thank you for your reply!
Would it be possible to access this IMU data after the flight? Does the DJI store this information in a way the user can access it? Is it time stamped and stored in a way where I can get the GPS coordinates and IMU at each time step?
For the camera angle I just would like to know it's actual angle at any time step.
So it total I would be asking if it is possible to know after the flight at each time step:
(GPS location, IMU data, and camera angle)
2024-12-12
DJI Natalia
edwinmeriaux Posted at 12-12 16:57
Hello!
Hi there, thank you elaborating the issue for etter understanding. Yes, it's possible to access IMU data, GPS coordinates, and camera angle information from your flight records. You may refer to the link below for video guidance on " how to check the flight records ".
[ https://support.dji.com/help/con ... ;paperDocType=paper }
Thank you for your understanding.
2024-12-13
edwinmeriaux
DJI Natalia Posted at 12-13 15:04
[ https://support.dji.com/help/content?customId=en-us03400006848&spaceId=34&re=US&lang=en&documentType=artical&paperDocType=paper }
Hello! Thank you for your answer. I see how i can get to my flight records but all I see is a flight log (I was using my friend's DJI mini 4 pro). I can see the trajectory of the flight and in the video I can see the altitude at each point but I cannot see any written log I can export? Is there a log like that?
Thanks!
2024-12-16
Labroides
Flight distance : 26781877 ft
edwinmeriaux Posted at 12-16 12:41
Thanks!
For what you are wanting you need to upload your flight data to here:
https://www.phantomhelp.com/logviewer/upload/
Follow the instructions the site provides.
When it gives you a summary report, click on the link under the map to give you a CSV file.
That will contain the data you are looking for
2024-12-16
