Circle tracking
264 4 2024-12-14
Falling Star
Czechia
Hello I am working on my project to let my robot gimbal follow a red circle.
I managed to tracked it using opencv but couldn't move the gimbal base on the x and y of the circle on the camera!
I am using this libraries: https://github.com/nanmu42/robomasterpy
and here is my code:
Thank you in advance
import logging
import multiprocessing as mp
import pickle
import queue
import threading
from typing import Tuple, List
import numpy as np
import click
import cv2 as cv
import robomasterpy as rm
from pynput import keyboard
from pynput.keyboard import Key, KeyCode
from robomasterpy import CTX
from robomasterpy import framework as rmf
from pynput.keyboard import Controller
import time
rm.LOG_LEVEL = logging.INFO
pickle.DEFAULT_PROTOCOL = pickle.HIGHEST_PROTOCOL
QUEUE_SIZE: int = 10
PUSH_FREQUENCY: int = 1
TIMEOUT_UNIT: float = 0.1
QUEUE_TIMEOUT: float = TIMEOUT_UNIT / PUSH_FREQUENCY
class TargetTracker:
    def __init__(self):
        self.delta_x = 0
        self.delta_y = 0
    # just display the streaming video
    def display(self, frame, **kwargs):
        # Adjust contrast
        alpha = 1.5  # Contrast control (1.0-3.0)
        beta = 0  # Brightness control (0-100)
        adjusted_frame = cv.convertScaleAbs(frame, alpha=alpha, beta=beta)
        # Convert the frame to HSV color space
        hsv_frame = cv.cvtColor(adjusted_frame, cv.COLOR_BGR2HSV)
        # Define the lower and upper bounds for red color in HSV
        lower_red1 = np.array([0, 120, 70])  # Lower range of red
        upper_red1 = np.array([10, 255, 255])  # Upper range of red
        lower_red2 = np.array([170, 120, 70])  # Lower range for another red hue
        upper_red2 = np.array([180, 255, 255])  # Upper range for another red hue
        # Create masks for red color (both ranges)
        mask1 = cv.inRange(hsv_frame, lower_red1, upper_red1)
        mask2 = cv.inRange(hsv_frame, lower_red2, upper_red2)
        red_mask = cv.bitwise_or(mask1, mask2)
        # Apply the mask to the original frame
        red_only = cv.bitwise_and(frame, frame, mask=red_mask)
        # Convert the masked frame to grayscale
        gray_frame = cv.cvtColor(red_only, cv.COLOR_BGR2GRAY)
        # Apply Gaussian blur to reduce noise
        blurred_frame = cv.GaussianBlur(gray_frame, (9, 9), 2)
        # Detect circles using Hough Circle Transform
        circles = cv.HoughCircles(
            blurred_frame,
            cv.HOUGH_GRADIENT,
            dp=1.2,  # Inverse ratio of the accumulator resolution to the image resolution
            minDist=50,  # Minimum distance between the centers of detected circles
            param1=50,  # Upper threshold for Canny edge detector
            param2=30,  # Threshold for center detection
            minRadius=10,  # Minimum circle radius
            maxRadius=100,  # Maximum circle radius
        # If circles are detected
        if circles is not None:
            circles = np.uint16(
                np.around(circles)
            )  # Round circle parameters to integers
            # Frame center for calculating deltas
            frame_center_x = frame.shape[1] // 2
            frame_center_y = frame.shape[0] // 2
            for circle in circles[0, :]:
                x, y, radius = circle
                # Calculate delta_x and delta_y
                self.delta_x = int(x) - frame_center_x
                self.delta_y = int(y) - frame_center_y
                # Expand the circular region slightly for better contrast calculation
                expanded_radius = int(radius * 1.2)  # Expand by 20%
                mask = np.zeros_like(gray_frame)  # Create a black mask
                cv.circle(
                    mask, (x, y), expanded_radius, 255, -1
                )  # Expanded white circle
                target_region = cv.bitwise_and(
                    gray_frame, gray_frame, mask=mask
                )  # Apply mask
                # Apply Gaussian blur to the target region for stability
                blurred_target_region = cv.GaussianBlur(target_region, (5, 5), 0)
                # Calculate the contrast in the target region
                target_pixels = blurred_target_region[
                    mask == 255
                ]  # Extract non-zero pixels
                if len(target_pixels) > 0:
                    mean, stddev = cv.meanStdDev(target_pixels)
                    contrast = stddev[0][0
                else:
                    contrast = 0
                # Draw the detected circle
                cv.circle(frame, (x, y), radius, (0, 255, 0), 2)  # Green circle outline
                # Draw the circle center
                cv.circle(frame, (x, y), 2, (255, 0, 0), 3)  # Blue center dot
                # Display contrast near the circle
                cv.putText(
                    frame,
                    f"Contrast: {contrast:.2f}",
                    (x - radius, y - radius - 20),  # Position text above the circle
                    cv.FONT_HERSHEY_SIMPLEX,
                    0.5,
                    (0, 255, 255),  # Yellow text
                    1,
                # Display delta_x and delta_y near the circle
                cv.putText(
                    frame,
                    f"Delta: ({self.delta_x:.0f}, {self.delta_y:.0f})",
                    (x - radius, y - radius - 40),  # Position text above contrast
                    0.5,
                    (255, 255, 255),  # White text
                    1,
        # Show the frame with detected circles, contrast, and deltas
        cv.imshow("frame", frame)
        cv.waitKey(1)
    # Follow the target by adjusting the gimbal
    def follow_target(self):
        if abs(self.delta_x) <= 30 and abs(self.delta_y) <= 30:
            return
        cmd = rm.Commander()
        if self.delta_x > 0:
            cmd.gimbal_move(0, -15)
        elif self.delta_x < 0:
            cmd.gimbal_move(0, 15)
        if self.delta_y > 0:
            cmd.gimbal_move(-15, 0)
        elif self.delta_y < 0:
            cmd.gimbal_move(15, 0)
def handle_event(
    cmd: rm.Commander, queues: Tuple[mp.Queue, ...], logger: logging.Logger
) -> None:
    push_queue, event_queue = queues
    try:
        push = push_queue.get(timeout=QUEUE_TIMEOUT)
        logger.info("push: %s", push)
    except queue.Empty:
        pass
    try:
        event = event_queue.get(timeout=QUEUE_TIMEOUT)
        # safety first
        if type(event) == rm.ArmorHitEvent:
            cmd.chassis_speed(0, 0, 0)
        logger.info("event: %s", event)
    except queue.Empty:
        pass
@click.command()
@click.option("--ip", default="", type=str, help="(Optional) IP of Robomaster EP")
@click.option(
    "--timeout", default=10.0, type=float, help="(Optional) Timeout for commands"
def cli(ip: str, timeout: float):
    # manager is in charge of communicating among processes
    manager: mp.managers.SyncManager = CTX.Manager()
    tracker = TargetTracker()
    global delta_x, delta_y
    with manager:
        # hub is the place to register your logic
        hub = rmf.Hub()
        cmd = rm.Commander(ip=ip, timeout=timeout)
        ip = cmd.get_ip()
        # initialize your Robomaster
        cmd.robot_mode(rm.MODE_FREE)
        # cmd.gimbal_recenter()
        # enable video streaming
        cmd.stream(True)
        # rm.Vision is a handler for video streaming
        # display is the callback function defined above
        hub.worker(rmf.Vision, "vision", (None, ip, tracker.display))
        # enable push and event
        cmd.chassis_push_on(PUSH_FREQUENCY, PUSH_FREQUENCY, PUSH_FREQUENCY)
        cmd.gimbal_push_on(PUSH_FREQUENCY)
        cmd.armor_sensitivity(10)
        cmd.armor_event(rm.ARMOR_HIT, True)
        cmd.sound_event(rm.SOUND_APPLAUSE, True)
        # the queues are where data flows
        push_queue = manager.Queue(QUEUE_SIZE)
        event_queue = manager.Queue(QUEUE_SIZE)
        # PushListener and EventListener handles push and event,
        # put parsed, well-defined data into queues.
        # hub.worker(rmf.Mind, "controller", ((), ip, control), {"loop": False})
        hub.worker(rmf.PushListener, "push", (push_queue,))
        hub.worker(rmf.EventListener, "event", (event_queue, ip))
        # Mind is the handler to let you bring your own controlling logic.
        # It can consume data from specified queues.
        # hub.worker(
        #     rmf.Mind, "event-handler", ((push_queue, event_queue), ip, handle_event)
        # a hub can have multiple Mind
        # follow_target(delta_x, delta_y)
        # Let's do this!
        hub.run()
    while True:
        tracker.follow_target()
if __name__ == "__main__":
    cli()
2024-12-14
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2024-12-14
Falling Star
Czechia
DAFlys Posted at 12-14 03:04
thank you for your suggestion I'll try to repost there
2024-12-14
DAFlys
Falling Star Posted at 12-14 03:12
Theres also the developer site Hi! -   From https://developer.dji.com you can click Forum to access it or a direct link to it is - https://sdk-forum.dji.net/hc/en-us/community/topics
2024-12-14
Montfrooij
Flight distance : 2845026 ft
Sounds like some interesting code.
2024-12-20
