Will switching off ground sensor result in longer flight times?
580 4 2015-10-5
Machoman
Flight distance : 1036959 ft
Austria
Does it send signal all the time if its switched on and consume power?
Is there anything unsafe disabling the ground sensor unless flying indoors?
I would like if the ground sensor would enforce a set minimum over ground level like telling it not go unter 2m over ground. and whenever the sensors detect 2m they hold this level. As Far as I know its not doing this now it lets you crash into the ground if there comes a hill.
2015-10-5
ibdronin
A good question.
2015-10-5
Tahoe_Ed
Flight distance : 2605 ft
The VPS system uses very little power.  If switched on you will see when it is active, normally below 2.5m.  You can turn it off if you do not need the feature and many do.  You can not set a minimum altitude with the VPS.
2015-10-5
Machoman
Austria
Tahoe_Ed Posted at 2015-10-5 18:28
The VPS system uses very little power.  If switched on you will see when it is active, normally belo ...
Does it have any advantage to have it switched on outdoors? More precision manual landing? More stable flight unter 2,5m over ground?
2015-10-5
Tahoe_Ed
Machoman Posted at 2015-10-5 10:13
Does it have any advantage to have it switched on outdoors? More precision manual landing? More st ...
Only if you do not have GPS lock.
2015-10-5
