P3 Pro - downgrade to 1.3.2 from 1.4.1 ?
2238 20 2015-10-5
RC Noob
since I don't use waypoints and such, I downgraded my P3 Pro from 1.4.1 to 1.3.2 after hearing about various issues like signal loss hitting some folks.  1.3.2 seems to work just as well for me.  I think (somewhat subjectively) that the 1.4.1 was causing a left drift when moving forward and ii had to adjust every now and then.
Anybody else downgrade to 1.3.2 like me?  Anything to watch with this version?
Thanks for your help.
2015-10-5
rolexian
How did you downgrade? I am having trouble finding a link to how to do that.
2015-10-5
sploodge
Flight distance : 809350 ft
1.3.20 is a solid firmware.. Didn't have a single issue with it.
Yo are correct about 1.4 that there seems to be some issues, mainly the loss of signal issue and the slight drift when flying in a straight line.. Hopefully these will be resolved in the next firmware ( mid to end of October it would seem ).
I'm living 1.4 though. The POI feature alone makes up for any other issues IMO
2015-10-5
dji2
Flight distance : 1263317 ft
I downgraded after excessive yaw to the left when going straight.   The problem isn't entirely resolved in 1.3.2 but it's much better.  Simply load the 1.3.2 firmware onto your SD card and turn on the P3 without turning on the RC.  It's just like any other firmware upgrade.
2015-10-5
rolexian
I heard that an update was coming in just a few days, due to all the error reports with 1.4
2015-10-5
rolexian
When I do what you did, all I get is this:
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
2015-10-5
RC Noob
You need a service bin file to flash the craft first, then the 1.3.2 install.  There was another post on this elsewhere.
2015-10-6
RC Noob
sploodge Posted at 2015-10-6 03:19
Yo are correct about 1.4 that ther ...
Thanks!! Loving my P3 Pro and this forum.
2015-10-6
rolexian
Don't suppose you have the service bin file?
2015-10-6
RC Noob
rolexian Posted at 2015-10-7 08:01
http://forum.dji.com/thread-23241-7-1.html?key=TVRRelkyRTJNak10WkRZeU55MWpObUUyTFdFNU1XVXRZbVZpWVdFNVltRmxOVEZp
Post 252
2015-10-7
jjejfjf
Banned
2015-10-7
jjejfjf
Banned
2015-10-7
rolexian
jjejfjf Posted at 2015-10-7 18:49
Did you get the service bin and did you try it? I found it but it mentions P3A. I have the P3P. Do ...
I did not do it. I looked around the forums and everyone is mentioned how you just load 1.3.2 on to your SD card and it should automatically downgrade.
2015-10-7
jjejfjf
Banned
2015-10-8
rolexian
jjejfjf Posted at 2015-10-8 04:52
Ill try it later today and get back to you. I dont know why some people would need the service bin ...
Any luck/update?
2015-10-9
gongml
Flight distance : 595413 ft
sploodge Posted at 2015-10-6 04:49
May I know what kind of signal loss issue you experienced?   Does it recover from signal loss after the drone gets back closer?  I wonder if the lost connection problem that I am running into is related to firmware; see my post on this...
2015-10-9
jjejfjf
Banned
2015-10-9
jjejfjf
Banned
2015-10-9
rolexian
jjejfjf Posted at 2015-10-9 17:07
Mine downgraded. I just 1.3.2 firmware on the sd card and did the normal upgrade procedure. I am n ...
Interesting. What does your installation log file say? Do you get camera transmission?
2015-10-9
jjejfjf
Banned
2015-10-9
Xterminator.971
splooge hi I need help I n'ais more video back to the controller I try my controller on another p3 AC works well so the problem of vien p3 (firmware)
here is my little log you give me your opinion?
[00054811]Delete history success.
[00055373]========== 2015.10.31 15:05:27. boot(15) ============
[00055444]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x10ce148d].
[00055517]Packet upgrade start...
[00055596]Packet checking...
[00055671]Packet vlink 01.04.0010 <-> 01.03.0020.
[00055750]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00055822]Done.
[00055897]Version checking[1]...
[00056015][03 05][00] v34.2.0.9 -> v34.2.0.9
[00056122][03 06][00] v2.3.0.13 -> v2.3.0.13
[00056200][04 00][00] v1.41.0.0 -> v1.41.0.0
[00056302][09 00][00] v1.7.0.3 -> v1.7.0.3
[00056453][11 00][00] v1.7.0.0 -> v1.7.0.0
[00056584][12 00][00] v1.10.0.0 -> v1.10.0.0
[00056684][12 01][00] v1.10.0.0 -> v1.10.0.0
[00056831][12 02][00] v1.10.0.0 -> v1.10.0.0
[00056963][12 03][00] v1.10.0.0 -> v1.10.0.0
[00069536][15 00][00] device not detected.
[00069663][17 00][00] v1.1.1.7 -> v1.1.1.7
[00069840][17 01][00] v1.0.2.7 -> v1.0.2.7
[00069949][19 00][00] v1.0.8.96 -> v1.0.8.96
[00070023][01 00][00] v1.23.3419 -> v1.23.3419
[00070101][01 01][00] v1.23.3419 -> v1.23.3419
[00082678][08 00][00] device not detected.
[00082754]Packet upgrade failed at version checking.
2015-11-5
