Motor kV
677 7 2024-12-23
PrivateView
Flight distance : 6190869 ft
Malaysia
I’m doing a research for simulator uncrashed drone settings. Does anyone know the kV for Neo motors and the standard rates, gain and expo for the drone. Thank you in advance.
2024-12-23
TheSkyIsForYou
Flight distance : 963287 ft
Poland
Hi there, I already did same research https://forum.dji.com/thread-327013-1-1.html
2024-12-23
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
Could you please clarify the specific research and purpose you are referring to?
Looking forward to your response.
2024-12-24
PrivateView
Malaysia
DJI Diana Posted at 12-24 04:40
Hi there,
It’s for training simulator, where I puts all the data in the simulator and the simulator will try to mirror the characteristic of Dji Neo drone.
The data needed is Neo motor kV/ max motor rpm, drone rates, gain, expo and propeller size.
With all this data could train in simulator to avoid crashing my drone.
Hope you can assist me here. Thanks in advance
2024-12-24
OldGuy2024
Flight distance : 632428 ft
JMHO,  keep it simple.  I use the CurryKitten sim to practice manual mode flying.  Just to develop improved neuromuscular coordinations.  You can play around with rates and expo if you want to. Then just start flying the Neo in manual mode with reduced max rates and play around with different center stick sensitivity and expo combinations.  If you want to reduce your chance of crashing when flying at low altitudes.  Just engage the ATTI option.  Limits your pitch angle no matter what max rate you set.  Nice thing about the FPV RC3 are two options to quickly bail out of manual mode when things go bad. Just hit the Brake/Pause switch or the mode rocker switch to N mode.
No quick and easy from stabilized modes to manual modes.  Just stick time on a sim and quad.  Crashing happens.  Part of FPV immersive flying.
2024-12-24
DJI Natalia
PrivateView Posted at 12-24 05:00
Hi, thank you for the explanation shared above. The motor kV value for DJI Neo will be 8500. I hope this clarifies your concern.
Thank you for your valued support.
2024-12-24
PrivateView
Malaysia
DJI Natalia Posted at 12-24 11:15
Wow, thank you.
2024-12-24
DJI Natalia
You're most welcome. Do not hesitate to contact us back if there's any further inquiry.
Thank you for your valued support!
2024-12-24
