Dji Terra / L2 Layer on corridor mode
272 1 2024-12-30
bruno.campi
Flight distance : 1581138 ft
hi everyone,
we set multiple flights during a big surveyor programmed as "corridor mode".
customer ask only for a coastriver of a big lake in our country.
now dji terra processed was fully completed, but noted that areas that cover blend of flights was little bit noised, maybe when 350 rotating for back ward L2 dont stop acquisition, and "multiple circle line" appears on model.
this "circle line" appears as noise, as you see on pics attached, but software create a little bit layer that create confusion on customer.
did you know how could we remove, next step processing, (ex terra solid that we not know how), decimaing, or simply processing by third part software in order to have a clear model?
Flights was taken by Emlid reach RS+ in rtk mode, then in all flights was inserted rinex files, so no layer was affected for a mismatched blend.
thanks
2024-12-30
adrianos
Flight distance : ****
Romania
You can get a trial of Lidar360 from GreenValley International and process the trajectory and cut out the parts where the drone did turns or other bad manouvers. I cannot help you with more info on that as my country projection is not supported in that software, but you can find more on their youtube channel and on others aswell. Hope it helps!
1-13 04:07
