soggybear
Hi,
I am seriously wishing I had not upgraded anything! Everything was working 2 days ago and had been for many months. This was the setup:
A2 flight controller with firmware 2.4m1
Z15-GH3 Gimbal which had a very early version of firmware (possibly before 1.0)
iOSD mk 2 with firmware 3.01. I am not using Lightbridge.
I use a Futaba 14SG Tx with connected via D-Bus. (Using the Futaba RX and the A2, I get more channels)
Monday I upgraded the A2 controller to the latest version 2.6. Then the fun began...
I no longer had control of the shutter. I figured the Zenmuse gimbal needed updating too so I updated the gimbal to the latest GCU firmware version 2.6 and IMU firmware 1.12. The shutter still did not work. I then realized from the manual that the gimbal had to be connected to Can 2 with this version so I did that. Still no shutter.
After reading various forums, I managed to roll back to A2 Controller firmware version 2.4. The shutter worked again.
My happiness was short lived when I realised that after one click of the shutter, the picture never returned on the FPV. If I cycle the power, the FPV works again until I press the shutter and the screen loses the feed from the camera but the iOSD information remains (satellites, height, distance...)
I have tried rolling back the gimbal firmware by using an earlier version of the gimbal assistant but the earliest version of the GCU firmware available seems to be 2.4. Is there a way of getting an earlier firmware version?
I am also a commercial operator in the UK and I really need this to work properly as soon as possible. Has anyone figured how to roll back to an early version of GCU firmware for the Z-15 GH3 which works??
The screenshots are how things are set up at the moment.
Any help would be appreciated! Thanks.
