13udo
Switzerland
Hello,
I cannot mount my Lidar on my camera's cold shoe, because I use a top handle and some other accessories that get in the way of the Lidar's sensor.
So I have a small 15mm rod set that extends the lidar out to my matte box and holds it flat.
However, when trying to calibrate, I notice that the angle of the Lidar is slightly different to that of the camera. Do I need to account for the slight angle change due to the height of the lidar mount? Does the DJI Lidar mount do this?
I have tried a couple times to calibrate a basic 24mm Sigma Lens, but each time, the Autofocus is not able to pick up what is in the center of my frame and I believe it's due to this mismatch in angle, but it also might be because of incorrect calibration technique?
Any info would be great thank you
