info.garage5
Switzerland
Hi, i am a Phantom 3 owner and now that the 5xRaw Ispire comes out, i am very tempted to go that road. In order to best match the Aerial shots with the other material it would be great to have same filtrations. We always have ir-Cut filter and black-frost Filter this makes 2 and together with an ND Filter wich is needed to not push f-stop further than f8 in bright daylight that would make 3 Filters.
My question, is that a problem for the Gimbal if there is more weight on the lens or should this be possible to achieve? also the Filter should probably be at least 52mm on 46mm threaded lens so there is no vignetting with 3 Filters, so you need step up ring, there are very light rings, but the bigger threaded filters add even more weight. Anyone have a clue?
thanks, Thomas
