DJI Wanda
Hi, there
Thanks for your patience.
When the Matrice 600/Matrice 600 Pro is connected to the Ronin-MX gimbal, the GPS data cannot be taken from the EXIF information in the photo. It can be taken from the flight controller data. How to export GPS data from the flight controller data:
1. Download and install the DJI Assistant 2 For Matrice onto your computer.
2. Connect the aircraft to the computer using a USB cable and run the DJI Assistant 2 For Matrice.
3. Tap the Matrice 600/Matrice 600 Pro aircraft icon and enter the DJI Assistant 2 For Matrice.
4. Tap Flight Data and enter microSD card mode. At this time, a disc named DJI FLY LOG will appear on the computer.
5. Open the Data Viewer and select flight data in the DJI FLY LOG disc.
6. Tap “Export GPS”. Select a storage path. Tap “Confirm” and a TXT file named GPS will be created.
7. Open the file to find the GPS information recorded by the flight controller each time the shutter is triggered.
If a RTK has been mounted and the RTK Valid value is 1, the GPS coordinate recorded by the flight controller will be the position data positioned by the RTK.Yaw Aircraft yaw angle displays the radian rather than angle. 0 refers to north. If the figure is positive, this indicates the counterclockwise direction. If the figure is negative, this indicates the counterclockwise direction. South is indicated as +3.14 or -3.14. Angle =180°× radian/π, as shown below. The angle is 180 × 0.16÷3.14=9.17°, northeast 9.17° |
